What Forces Create Torque on a Merry-Go-Round?
  • Thread starter Thread starter biomajor009
    Torque
biomajor009
What forces produce a torque on a merry-go-round?
This question is vague to the point of absurdity. Any force could produce a torque on anything provided it is applied in any direction that is NOT toward nor away from the center of rotation.
