What is the pressure surrounding a liquid at its boiling point?
The pressure surrounding a liquid at its boiling point is defined as the atmospheric pressure that equals the vapor pressure of the liquid. For example, at room temperature (20°C), the pressure surrounding water in an open pot is 1 atm. In a closed system, such as a pressurized container, the surrounding pressure can vary based on the initial conditions and the presence of air. If the container is sealed, the vapor pressure generated at boiling point can increase the total pressure within the tank, depending on the initial conditions.
  • Understanding of vapor pressure and boiling point concepts
  • Knowledge of atmospheric pressure (1 atm) and its implications
  • Familiarity with closed systems and pressurized containers
  • Basic principles of thermodynamics related to phase changes
  • Research the relationship between vapor pressure and temperature in liquids
  • Learn about the effects of pressure on boiling points in closed systems
  • Study the principles of thermodynamics related to phase transitions
  • Explore the behavior of gases in pressurized environments
Students and professionals in physics, chemistry, and engineering, particularly those interested in thermodynamics and fluid mechanics.
dromeascr
Member advised to use the formatting template for all homework help requests
Hello everyone, before I start I just want to mention that I am not an expert in physics whatsoever, so please be as specific as you can get if you wish to provide an answer. (The question itself might be considered stupid to be honest)
I read the definition of the boiling point recently and according to wikipedia, boiling point is the temperature at which the vapor pressure equals the pressure surrounding the liquid. So my question is, what exactly is the pressure surrounding the liquid? For example we have a pot filled with water in room conditions (20C, 1 atm pressure). What is the value of the pressure surrounding the liquid at such conditions? If we warm up the pot and vapor starts getting generated, will that also increase the atmospheric pressure within the room as well?
In case of a pressurized container or cargo tank, what is again the pressure surrounding the liquid? At boiling point, the vapor pressure generated will double the pressure within the tank?
Thanks for your time in advance if you take the time to reply. It would be super helpful.
dromeascr said:
1 atm
Only if the room is unvented.
Whatever the pressure happens to be; presumably the tank is closed/sealed, and may be regarded as a "system."
It depends on whether air is in the tank to start with. Also, in a closed tank with air, the boiling point will be increasing as the temperature rises (and you continue to add heat).
  • · Replies 23 ·
