Question about Variable Change used in Differentiation
8 replies · 2K views
hokhani
variable change of a differentiation
##\frac{df(x)}{dx}##
Consider differentiation ##\frac{df(x)}{dx}##. If we change the variable as ##x=-u## how does the differentiation change? Does it change as ##\frac{df(-u)}{-du}##?
hokhani said:
Homework Statement: variable change of a differentiation
Relevant Equations: ##\frac{df(x)}{dx}##
You must consider what a change of variable means. In general, you have a function ##x = g(u)##. That allows us to define a new function by composition:
$$h(u) = f(x) = f(g(u))$$We can now apply the chain rule to get:
$$h'(u) = f'(g(u))g'(u)$$In the case where ##g(u) = -u##, we have ##g'(u) = -1## and:
$$h'(u) = -f'(-u)$$Note that many textbooks will use the same function symbol ##f## for both the original function and the composite function ##h## here. And you end up with $$f'(-x) = -f'(x)$$or $$\frac{df(-x)}{dx} = - \frac{df(x)}{dx}$$PS note that, strictly speaking, these last two are wrong - but they are very common, especially in physics textbooks.
Reply
You need to be careful, especially for even functions, with how you interpret your expression, ##\frac{df(-u)}{-du}##. You have not indicated what you think this means as a function of ##u##. I think that you should apply the Chain rule as @PeroK describes. That will help you to keep the calculations straight.
Thanks, by ##f'(-u)## do you mean ##\frac{df(-u)}{d(-u)}## or ##\frac{df(-u)}{d(u)}##?
## f'(-u) ## means ## \frac{df(-u)}{d(-u)} ##.
I don't really use that notation myself. Given a differentiable function ##f##, ##f' \equiv \frac {df}{dx}## is a well-defined function. Where the second formulation entails the use of a dummy variable ##x##. Both ##f## and ##f'## can be applied to any variable, so we can write:
$$f(u), f'(u) \equiv \frac{df}{dx}(u) \equiv \frac{df}{dx}\bigg |_u$$I avoid things like ##\frac{df(-u)}{d(-u)}##, as they are ambiguous and confusing to me.
Reply
Let's take an example and let ##f(x) = \sin x##, so that ##f'(x) \equiv \frac{df}{dx} = \cos x##. In this case:
$$f(-u) = \sin(-u), \text{and} \ f'(-u) = \cos(-u)$$However, if we define:
$$h(u) = \sin(-u)$$then$$h'(u) \equiv \frac{dh}{du} = -\cos(-u) = -f'(u)$$Everything else involves an abuse of notation to some extent - which I prefer to avoid.
... and ## -f'(-u) ## means ## \frac{df(-u)}{du} ##.
