Time, Mass & Space: Does Time Stay Consistent?
  • Thread starter Thread starter pnorris2000
    Time
The discussion centers on whether time remains consistent throughout the universe, particularly in relation to mass and the absence of mass in the voids of space. It is established that time and space are intertwined, with time being relative to mass, especially near black holes, where observers experience different time passage despite seeing time flow uniformly. The absence of mass in empty space does not appear to affect time's consistency, and light travels at a constant speed in a vacuum, although its travel time can vary based on the curvature of space-time. The conversation emphasizes the importance of specific observations to better understand the nature of time. Ultimately, while time is relative, there is no evidence suggesting it behaves inconsistently across the universe.
pnorris2000
My question is: do we know that time stays consistant throughout all the universe. We know that time and space are intertwined, and that time is relative depending on mass, such as near an event horizon. Does the absence of any mass, out in the voids of space, between galaxies, also affect time's consistancy? If not, would light pass though these areas at a different rate comparatively?
Space news on Phys.org
There is no reason to believe otherwise.
yes, they are part of the same thing
No, we don't "know" that, since it's not true as regards the event horizon of a black hole. What is true is that observations from far away from an event horizon show an appearance of time slowing down but we know that the time for the object AT the event horizon is not affected at all by the event horizon (which isn't even a physical thing, just a coordinate).
What is also true is that if you were to approach such an event horizon and then return to a starting point far away from the BH, you would have experienced a different amount of time's passage than would someone who had just stayed at your starting point. Both of you, however, would see no difference in the rate of time flow. It flows at one second per second for both of you but you have taken different paths through space-time and so have experience different numbers of seconds.
There is no reason to believe so.
Not clear what this even means. Light travels at c in a vacuum regardless of any nearby mass but the amount of time it can take to get from point A to point B can depend on the path that it takes through space-time so the light in an Einstein Ring, for example, will have taken longer to get to us than it would have had there been no intervening mass that "bent" the light back towards us and the light had just come directly towards us.
What does "time stays consistent" mean? How would you test to see whether time "stays consistent" or not?
What does "time is relative depending on mass" mean? How does it show up in experiments?
The point of my questions is to get you to think in terms of actual specific observations. I think that will help you to better focus your questions.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
