Question on microcontroller
  1. Apr 1, 2014 #1
    I don't understand what does mean of following statement
    processor take signal from switch via the input port and send processor the signal signal to motor via output port
    is this correct statement or not ?
    tell me only, is this correct statement or not ?
    If yes then result should be store in which memory rom or ram?
    I think ram memory but I am not sure
  3. Apr 1, 2014 #2
    berkeman
    Staff: Mentor
    Let's say you are using a microcontroller (uC) that has an 8-bit data bus width. Then each register or port will be 1 byte wide. The uC reads from the address of the input port, and gets an 8-bit value. Each of the bits can represent an input, like from a switch or from a sensor, etc.
    When the uC writes to an output port, it writes an 8-bit value, and each of those bits can control some output thing, like light an LED or turn on a motor, etc.
    The locations that you fetch information from and save results to are specified by your program. If you are writing in C for example, in the first part of your program you will declare your variables and how big they are, and if you want to force them to be located at some particular location in the memory map (like if you want to do reads and writes from the IO ports, for example, as opposed to some variable that is located somewhere in RAM and you don't care where it is).
  4. Apr 1, 2014 #3
    mcro controller contain mainly ALU, control unit ROM , RAM, PORT
    Processor take information from ROM, RAM, Input port
    fetching - decoder take command from rom memory
    decode - decoder decode instruction and tell the cpu what to do like add, sub
    execution- alu do the operation like add, sub.. and sand the result into rom memory
    we have fetched , decoded and executed instruction but where does we use ram memory
  5. Apr 1, 2014 #4
    berkeman
    Staff: Mentor
    It looks like you have been doing some reading about uCs, which is good! :smile:
    Can you point us to what you've been reading? That would make it easier to answer your questions about that reading.
  6. Apr 1, 2014 #5
    yes you are correct I am reading about ram memory , BUT I don't understand how does ram work when instructions fetch, decode, and execute
    I just want to ask when does ram work?
    when micro controller do work
    there may be done three process
    fetching, decode and executing
    during all process when does ram work?
  7. Apr 1, 2014 #6
    berkeman
    Staff: Mentor
    You did not answer my question by posting a link to your reading. Do you understand that it would be *much* easier to answer your question if you gave us a pointer to what you are reading?
  8. Apr 1, 2014 #7
    berkeman
    Staff: Mentor
  9. Apr 2, 2014 #8
    I have given answer look at my previous post
    I don't understand how does ram work when instruction fetch, decode and execute
  10. Apr 18, 2014 #9
    First off all instructions are timed with a processor clock, when a Ram address is decoded via a decoder addressing circuit. Upon a chip enable instruction, via the CPU clock several signals are generated within a specific timing. the chip enable, the decoded Ram address, which is both a row and column address scheme. then data is written to the specified address location.
    whether the RAM reads or writes is also controlled via one or two pins
    If you look at a Ram chip and download the data sheet for that chip, it will provide the required signals and timing. Examine also the pin-out scheme. Ram cannot run by itself you need to look at the full circuit necessary to control a RAM module. As well as research the specific signals and timing. The specifics depend on the RAM module itself, so without further information from you we cannot help you further. IE we need to know your reference material
    edit forgot to mention each RAM memory bit is essentially a flip flop circuit, you can google that
  11. Apr 26, 2014 #10
    everyone say start with basics so I am trying to understand in this way
    Instruction + register +address +data ; statement for my understanding (idea)
    mov + A + ? +02 ; assembly code ; statement for assembler (assembler)
    01 + 10 + 01 + 01 ; binary digit ; statement for controller
    off on + on off +off on +of on ; transistor on off
    0,5v +5v ,0v +0v , 5v +0v 5v ; voltage level
    can anyone help me In this way
  12. Apr 26, 2014 #11
    I'm sorry but the above doesn't give me enough to assist you. Which processor are you working on, Intel, PICO, Motorolla. If your looking for the assembly instructions and the hexadecimal conversions, with the correct OP codes we need to know this. We also won't be able to describe how the instructions work with the hardware addressing, such as the ALU addressing of the microprocessor to memory module location without knowing which system your working with
  13. Apr 26, 2014 #12
    Thanks for reply I am talking about 8051
  14. Apr 26, 2014 #13
    Now we can work with you, unfortunately I never worked on the 8051, however finding the information is easy enough.
    here is the 8051 architecture
    http://www.mikroe.com/chapters/view/65/chapter-2-8051-microcontroller-architecture/
    here is your much needed manual it has coverage of the architecture, with programming examples including memory.
    http://cse.iitkgp.ac.in/~soumya/embcs/the-8051-microcontroller-0314772782.pdf [Broken]
    those will answer your questions, just work through the pdf file if you have further questions include the manual in your related posts, so others can look through it and help you with specific sections
Similar Discussions: Question on microcontroller
Loading...
