Question regarding trinomial expansion
  • Thread starter Thread starter Hectorreturns
    Expansion
The discussion focuses on expanding the expression (1 - 2tw + t^2)^(-1/2) to find the coefficient of t^2. Participants clarify that the expression lacks an equation format, emphasizing it is an expression rather than an equation. They suggest using the binomial theorem for expansion, specifically by substituting x with 2tw - t^2 to find the coefficients of x^0, x^1, and x^2. The conversation highlights the challenges of dealing with negative exponents in trinomials. Overall, the key takeaway is the method for determining coefficients in the specified expansion.
Hectorreturns
The co-efficient of t2 in the expansion of given equation is : (t<<1)
(1 - 2tw + t2)-1/2
I have never expanded trinomials with negative exponents. In the absence of w, it could be expanded with binomial theorem but with w I don't understand how to solve it.
(1 - 2tw + t2)-1/2
I don't see anything with an '=' sign in it, so I don't see an equation. However, I do see an *expression*.
Anyway, do you know how to find the coefficients of ##x^0 = 1##, ##x^1## and ##x^2## in the expansion of ##f(x) = (1 - x)^{-1/2}?## If so, just set ##x = 2wt - t^2.##
Yeah *expression* instead of equation and thanks for the tip.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
