Questioning Physics: Is Mass-Energy Conversion Possible?
  • Context: Undergrad
  • Thread starter Thread starter wilhelm96
    Physics
The discussion revolves around the theoretical possibility of a machine that converts mass into energy, specifically examining the implications of mass-energy equivalence as described by the equation E=mc². Participants explore the conversion of carbon and oxygen into carbon dioxide and the associated energy changes, touching on concepts of binding energy and annihilation.
  • One participant questions the feasibility of a machine that converts mass into energy, specifically addressing the energy dynamics when converting carbon and oxygen into carbon dioxide.
  • Another participant cites the conservation of baryon number as a fundamental law preventing the complete conversion of mass (in this case, CO2) into energy, suggesting that some mass must remain to conserve baryon number.
  • A different viewpoint introduces the concept of annihilation, where matter and antimatter can convert entirely into energy, noting that this process achieves 100% efficiency in conversion.
  • One participant discusses the binding energy involved in the formation of CO2 from its constituent elements, suggesting that this energy is a factor in the mass difference observed when measuring the components separately versus the compound.
  • Another participant corrects a previous claim, stating that the formation of CO2 from carbon and oxygen is exothermic, meaning it releases energy rather than requiring additional energy, and emphasizes that CO2 has less mass than the separate elements combined.
Participants express differing views on the feasibility of mass-energy conversion and the implications of binding energy, with some asserting that a machine for such conversion is impossible, while others explore hypothetical scenarios. The discussion remains unresolved regarding the specifics of energy changes in chemical reactions versus theoretical mass-energy conversion.
Participants reference concepts such as binding energy and baryon number conservation, but there are unresolved assumptions regarding the definitions and implications of these terms in the context of the discussion.
wilhelm96
Hope this theoretical question isn't too stupid, just my physics teacher couldn't give me a satisfying answer and I am only 14. (english is also not my mothertongue, pls excuse grammatical failures)
So what if there was some sort of machine, that would just convert mass into energy after e=mc².
If you were to feed this machine first with 1 kg of CO², you'd get 9 GJ.
If you were then to feed this machine with the aquivalent of C and O needed to produce 1kg of CO², but seperatly, you'd still get out the 9 GJ.
But what happened with the theoretical chemical Energy C and O has?
Does it maybe get lost when C and O becomes plasma thus releasing the energy held by the angle of the electron pairs to each other?
So, doesn't that also mean, that no such machine could exist, without having to heat up the mass to a very high point?
The "empirical" law of baryon number conservation (the sum of protons plus neutrons) prevents conversion of 1 Kg of CO2 (~500 g of protons, ~500 g of neutrons, ~0.25 g of electrons) into pure energy. Excluding considering nuclear binding energies, 1 kG of protons and 0.5 g of electrons would have the least mass that conserves baryon number.
Bob S
There is no machine you can use, but there is a physical processs called Annihilation. When a particle and its antiparticle (electron positron for example) 'collide' the result is a total conversion of MATTER to energy. It should be noted that it's matter you're thinking of, not mass... mass is present as a function of energy-momentum too.
If you take a molecule of helium, and anti-helium, the result is a total conversion from matter to energy, including all of the binding energies: chemical, molecular, atomic. Annihilation is the only means that I know of which conceivably gives 100% efficiency for conversion.
Such a machine would indeed be impossible when taking into regard some advanced physics.
However, let's assume for now we could make such a machine. It is true that to make CO2 from the separate components takes some energy. This energy can be found by precisly weighing C and O seperatly and then weighing the combination: CO2. You would find that the CO2 is ever so slight heavier than the weight of a C and two O's added! The difference in weight is minute, a lot smaller than 1%. But precisly that weight is the energy (through E-mc^2) that it takes to bind the C and O atoms. It is called the binding energy. So feeding the machine CO2 would make it produce a little more energy.
Good question!
Huh? You have this reversed.
The C + O -> CO2 reaction is exothermic (gives off energy). This is normal every-day combustion. It is, in fact, a very common reaction. You see it when charcoal burns in your barbecue grill. The heat of the charcoal comes from this reaction.
C and O want to combine because the combination has LESS mass, NOT MORE. CO2 has less mass than C and 2 O.
Binding energy is the mechanical energy required to disassemble a whole into separate parts. A bound system has typically a lower potential energy than its constituent parts; this is what keeps the system together- often this means that energy is released upon the creation of a bound state. The usual convention is that this corresponds to a positive binding energy.
(bold is mine)
You're right, my bad.
  • · Replies 18 ·
  • · Replies 0 ·
  • · Replies 17 ·
