Questions about imaginary number and root of 4
Imaginary numbers, such as "i," cannot be compared to real numbers like 5, as there is no established ordering for complex numbers. When discussing complex numbers like Z_1 = 4 + 5i and Z_2 = 1 - 3i, neither can be said to be greater than the other without specifying absolute values, which represent their distances from the origin in the complex plane. The square root of 4 is defined as 2, not -2, because we conventionally assign the principal square root to be non-negative. The reciprocal of a complex number remains a complex number unless it is zero, and its geometric interpretation can relate to concepts like circle inversion. Overall, comparisons of complex numbers should focus on their magnitudes rather than their real or imaginary parts.
Shing
I am thinking that
if the imaginary number is bigger than the other number,
is it right to say that:
i> 5 ?
7i> 3i ?
Does i has magnitude?
if
Z_1=4+5i
then
Z_2=1-3i
whether Z_1>Z_2 or Z_2>Z_1 is true?
If we say Z_a is bigger than Z_b, does that means the absolute value of these complex number?
Thank you :)
Mathematics news on Phys.org
Also
I have been wonder why \sqrt{4} =2
but why NOT -2, negative two?
Shing said:
I am thinking that
i> 5 ?
7i> 3i ?
if
Z_1=4+5i
then
Z_2=1-3i
If we say Z_a is bigger than Z_b, does that means the absooluate value of these complex number?
Thank you :)
No, "i" is not bigger than any real number.
As it happens, when we talk about complex and imaginary numbers, we cannot have an ordering relation between them.
Numerous complex numbers will have the same magnitude, so that a number's magnitude cannot serve as an identificatory trait of that number.
Shing said:
Also
Good question!
Answer:
Because we have, by convenience, DEFINED the square root thusly.
Similarly, by convenience, we have defined 1 not to be a prime number.
Shing said:
I am thinking that
i> 5 ?
7i> 3i ?
It is not possible to assign an "order" to the complex numbers in such a way as to have an "ordered field" (that is, so that if a< b and 0< c, then ac< bc and if a< b, then a+c< b+ c (for any c)). For example, if we were to define an order so that 0< i, then we must have 0*i< i*i or 0< -1. Since this is not necessarily "regular order" that is not a contradiction itself but multiplying by i again, 0*i< -1*i or 0< -i. Adding i to both sides, we must have 0+i< -i+ i or i< 0, contradicting 0< i. But if we try to define an order so that i< 0, we can, in the same way, show that 0< i getting the same contradiction.
if
Z_1=4+5i
then
Z_2=1-3i
whether Z_1&gt;Z_2 or Z_2&gt;Z_1 is true?
Neither is true- as I just showed there is no way to compare complex numbers.
I've never seen anyone say that Za> Zb for Za and Zb complex numbers. If you mean to say one has larger absolute value than the other, then you must say |Za|> |Zb|.
Shing said:
Also
We define it that way because fractional powers with even denominators give real results only for positive numbers. If we want to be able to say that \sqrt{x}= x^{1/2} (which is a very useful thing to do) and then combine it with other such functions, we need to stick to positive numbers.
Thank you so much, Arildno and HallsofIvy!:smile:
But I don't understand that,would you explain a bit more please?
We define it that way because fractional powers with even denominators give real results only for positive numbers. If we want to be able to say that Click to see the LaTeX code for this image (which is a very useful thing to do) and then combine it with other such functions, we need to stick to positive numbers.
imaginary number is so amusing, I am thinking of the geometry meaning of some operations of complex number.
I was thinking if these are true:
Z_1\times Z_2 produce a new complex number "vector" Z_3
{Z_1}^{1/2}\times {Z_2}^{1/2}produce a new complex numberZ_3 too
When I was thinking of the reciprocal of a complex number Z_1
{1\over {Z_1}} = {{x-iy}\over {x^2+y^2}}
I was shocked!
Does that mean {1\over {Z_1}} is Z_1* times the reciprocal of the area of the square magnitude of Z_1(|Z_1|^2)?
If so, what is the meaning of a reciprocal of an area?
Also, is {1\over {Z_1}} still a complex number?
Yes, it is, unless Z_1 is zero.
Try to relate the geometric meaning of 1/z to the circle inversion.
Shing said:
I am thinking that
i> 5 ?
7i> 3i ?
if
Z_1=4+5i
then
Z_2=1-3i
Thank you :)
"i" is nothin..as we say an imaginary number n nothin else..when we say that Za is greater than Zb..we mean to take their real part n not the imaginary parts
You can however compare absolute values of complexes. If you have Z_1=4+5i and Z_2=1-3i then you can look at |Z_1| and |Z_2|.
This will tell you the complex numbers distance away from zero in the complex plane.
In general let Z = a+Bi then |Z| = \sqrt{a^2 + b^2}
Now you can say |Z_1|&gt;|Z_2|.
I have never seen such a statement! And, exactly what do you mean by '"i" is nothin"?
I have never seen anyone say "Za> Zb" when they meant Re(Z_a)> Re(Z_b). And what do you mean by ' "i" is nothin'?
