What Would You Ask Nagin Cox at JPL?
  • Thread starter Thread starter BilboBombadillo
A private tour of the Jet Propulsion Laboratory (JPL) in California is being organized, featuring Nagin Cox, known for her work on the Curiosity rover. Participants are encouraged to submit questions they would like to ask her during the tour. The discussion highlights the opportunity to engage with a prominent figure in space exploration. Nagin Cox's Twitter feed is shared as a resource for more information about her work and insights. This event presents a unique chance to learn directly from an expert in the field of planetary science.
BilboBombadillo
Hey there - so I'm potentially going on a private tour of the jet propulsion laboratory here in California. It will be myself and two friends of mine, accompanying Nagin Cox, of the Curiosity rover.
Is there anything you'd like to know?
Likes Greg Bernhardt
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
