StevieTNZ
- 1,934
- 873
In regards to the experiment mentioned in this paper - http://arxiv.org/abs/1001.4785
(1) I understand that the particle goes along both paths to cause interference when the two paths cross each other... at that stage we don't have definite which-path information. But after the crossing, each path leads to the appropriate detector. Only one detector will click. Can we be sure that if detector 1 clicks, the particle really followed the path indicated in the diagram? Is it possible that sometimes detector 2 will click in this experiment (and that if detector 2 does click, the particle followed the opposite path to if detector 1 clicked)?
(2) Would it be correct to say that there is no violation of the complementary principle, because interference was observed at a different time to when we were certain we knew which path the particle followed? I'd would assume that interference is no longer there after the intersection of paths is finished. The particle should continue towards a detector and not stay in the intersection area.
In a way, we know by what detector clicks we can tell which path the particle followed. But we can only be definitely sure once we know what detector has clicked. Otherwise we can only say 50% of the time detector 1 will click, and 50% of the time detector 2 will click. I can't say that is which-path information in the sense that it is definite.
Should there be interference in the first place, if in fact we are in principle able to tell which path the particle went along (despite this measurement occurring after interference is seen)? Being able to distinguish the paths, in principle, should not allow interference to occur at all, right?
