Questions on phase space and CanonicalMicrocanonical ensembles
The discussion revolves around the analysis of phase space for a weight in free fall and the calculation of thermodynamic properties for a one-dimensional lattice model. Participants seek clarification on sketching phase space trajectories and calculating density of states, entropy, and temperature based on given interaction energies. There is confusion regarding the highest and lowest energy states, with some suggesting potential errors in the problem's formulation. Additionally, questions arise about the differences between canonical and microcanonical ensembles, particularly concerning the definitions of microstates and density of states. Overall, the thread highlights the complexities of statistical mechanics and the need for a deeper understanding of the underlying concepts.
thermodynam..
1. Sketch the phase space of a weight free falling along the z coordinate (no
motion in other directions). Sketch the trajectory of the free fall including
impact on the ground.
2. Calculate the density of states, entropy, and temperature (all as a function of
energy) for the following model: Consider a 1 dimensional lattice with 3 elds
(periodic boundary conditions). Every lattice site can have the states ; 0; +.
Interaction energies are only between nearest neighbors and are E() = +4
E(++) = +3 E(+) = E(+) = 2 everything else E = 0. Sketch the highest
and lowest energy states.
3. Dierences: CanonicalMicrocanonical ensemble
Assume you have given a density of states as a function of energy
(E). This can be used to calculate canonical and microcanonical data.
(a) Discretize Energy in units of E and write down the entropy microcanoni-
cally.
(b) Give the partition sum in the canonical and the microcanonical ensemble
(as a function of the relevant observables).
(c) Assume you measure an observable as a function of energy A(E). Write
down its average canonically and microcanonically.
2.
3. I don't know how to sketch in problem 1 and for problem 2, I think maybe there are mistakes in the problem, otherwise, the highest energy should be +∞ and the lowest is -∞. Problem 3 I totally have no idea of it, and I want to know the difference and relation between Ω(the number of microstates) and Ω'(the density of states).
Do you know the definitions of any of those things? Whoever gave you this problem certainly expects you to know them.
(And this problem is physics, not mathematics, so I am moving it.)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
