Questions regarding rotational motion
The discussion focuses on calculating the angular position of a reference dot on a computer disk after a period of acceleration and steady motion. The disk accelerates to 2000 rpm in 0.5 seconds, and the user has determined angular acceleration and tangential and centripetal accelerations. The solution involves breaking the motion into two parts: the accelerated phase and the constant speed phase, applying the appropriate rotational motion equations for each segment. There is a suggestion to use analogous linear equations to derive the rotational formulas needed for calculations. The conversation emphasizes the need for clarity in applying these formulas correctly to find the total angular position at 1 second.
dismalice
A computer disk is 8.0 cm in diameter. A reference dot on the edge of the disk is initially located at The disk accelerates steadily for 0.50 s, reaching 2000 rpm, then coasts at steady angular velocity for another 0.50 s.
I have found that a_t=17 m/s^2 @ .25s
a_c = 440 m/s^2 @ .25s
and v = 8.4 m/s @ 1s
I need to find the angular position of the reference dot @ t=1s
Theta = Theta(not) + (Alpha T^2)/2
s=rTheta
Alpha= dW/dT = 2000 (2pi/60) = 209.44 rad/s
Theta= 0+ ((alpha)t^2)/2) + (alpha*t^2) = 314.16 rad
I think you have to do it in two parts.
First the accelerated part, then the constant speed part.
No one formula applies to the whole motion.
Could you please give me an example, I am not quite clear on what you are saying.
For the first .5 seconds, it is accelerated, so use your
Oops, I don't think that is quite right - better look it up.
I think the rotational formulas are analagous to the linear ones, so think
D = V1*t + ½ at²
and change the D to θ, the V1 to ω1, the a to alpha.
The formula for the second part will be analgous to d = vt.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
