Quick Correlation and Causality: A Scientist's Perspective
  • Thread starter Thread starter clane
    Correlation
A correlation coefficient near zero does not definitively indicate the absence of causality, as causality can exist without a linear correlation. While a lack of correlation suggests that two variables are not linearly dependent, they may still have a non-linear relationship. Thus, one cannot conclude that zero correlation equates to no causality without ruling out non-linear dependencies. It's essential to consider the nature of the relationship between the variables when interpreting correlation data. Understanding these nuances is crucial for accurate scientific analysis.
clane
Hello All,
I am trying to look at some correlation numbers and while I am aware that correlation does not always indicate causality can a correlation coeffiecent that is very near to zero be used to indicate that it is not a cause?
Thanks
C
Elementary logic should give you the answer.
Causality => correlation.
Therefore: not correlation => not causality.
Let's be careful.
Causality does not always imply correlation because the relationship may be nonlinear. Correlation is a linear relationship.
If two variables are dependent, their relationship can be linear or nonlinear. If it's linear, their correlation will be significant. If their corr. is not significant, then you can say that the variables are not LINEARLY dependent on each other. But, they can still be non-linearly dependent.
So the answer is technically "No, a zero correlation does not mean no causality." A more roundabout way of putting it is: "A zero correlation would imply no causality only if a non-linear relationship can be excluded on other grounds."
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
