Quick De Moivre's Theorem question
  • Thread starter Thread starter ZedCar
    Theorem
Using De Moivre's Theorem, the angle can be expressed in either degrees or radians without affecting the validity of the calculation. When the angle (√3 + i) is raised to the power of 7, the result remains consistent whether 210° or 7π/6 is used. Both representations yield the same final outcome due to the equivalence of the angle measurements. This flexibility allows for easier calculations depending on the preferred unit of measurement. Therefore, both methods are equally valid for solving the problem.
ZedCar
In example 1 on this webpage;
http://www.cliffsnotes.com/study_guide/De-Moivres-Theorem.topicArticleId-11658,articleId-11634.html
(√3 + i)^7
You'll see that the angle is inserted in degrees, and then in the working out the degree angles are multiplied by the power of 7, to give 210°
If the angle had been inserted in radians i.e. ∏/6 and multiplied by the power of 7 also, to give 7∏/6 in the working out (instead of 210°), would this be equally valid?
π radian corresponds to 180°. 210° is equivalent to (210/180) π = 7π/6.
ehild
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
