Calculating Enthalpy Changes in Aqueous Reactions: A Quick Guide"
  • Thread starter Thread starter mrjeffy321
In chemical reactions involving aqueous products or reactants, it is often necessary to consider the enthalpy values of the individual ions rather than the compound as a whole, especially when specific enthalpy values for certain compounds, like NaOCl, are not readily available. For example, in the reaction between iron and sodium hypochlorite, breaking down NaOCl into its constituent ions (Na+ and Cl-) can simplify calculations. However, it is essential to accurately account for the oxidation states and the enthalpy of formation for each ion involved, including the solvation and lattice energies. The complexity of these calculations arises from the need to integrate various energy components, such as solvation energy for ions and lattice energy for solid products like Fe2O3. Properly understanding these factors is crucial for calculating the overall enthalpy change of the reaction.
mrjeffy321
In a reaction, if I have a product/reactant that is aqueous, do I use the values of enthalpy for their ions?
for example:
2Fe (s) + 3NaOCl(aq) --> Fe2O3 (s) + 3NaCl(aq)
which could also be:
2Fe (s) + 3Na-1(aq) + 3O+2(aq) + 3Cl-1(aq) --> Fe2O3 (s) + 3Na+1(aq) + 3Cl-1(aq)
since I can't find a value for the enthalpy of NaOCl, then this would work out nicely to use the ions, and I don't see an aqueous enthalpy value for NaCl, so this is why I am thinking that I should use the ion's enthalpy, am I right.
Chemistry news on Phys.org
but then again, if this is true, then I would need to have the values of enthalpy for a sodium ion that is negative 1, rather than positive, and what an oxygen ion?
I don't believe so. The enthalpy of formation of the following aqueous compounds is the net enthalpy of formation from the corresponding elements from their most stable states; there are substeps involved, one of these substeps I believe pertains to solvation...formation of ions, then solvation.
Online help with chemistry
http://groups.msn.com/GeneralChemistryHomework/
mrjeffy,
I see you're still rusting, with bleach this time - for your thermit weld, I guess ?
Okay, you've gotten the oxidation states in NaOCl wrong - it should be Na(+1)O(-2)Cl(+1). It's the Chlorine ion that has a weird state. I'm sure the the reduction potential for :
Cl(+1) + 2e- ---> Cl (-1) is documented.
From this, you can calculate the Free Energy change, and from that, the enthalpy change.
But it's not so simple, because you will also have to use the solvation energy for O(-2) as well as the lattice energy for Fe2O3 OR the ionization and lattice energies for Fe - depending on what data you use.
yes, I am still rusting, but mostly just trying to organize all this data I have and get rid of all the scrap paper I have laying around, so I can have all the info I could possibly ever want on these reactions without the clutter.
ok, all see what I can do with this method of doing it.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
