Quick Entropy / Enthelpy Question
  • Thread starter Thread starter Brimley
    Entropy
The discussion revolves around calculating the change in enthalpy (ΔH) and entropy (ΔS) for a lead-acid battery using the Gibbs Free Energy equation. The user initially calculates ΔG using the known open circuit voltage (OCV) and other parameters but struggles to find ΔH and ΔS due to having two unknowns and only one equation. Participants suggest that to solve for these two unknowns, multiple values of ΔG at different temperatures are needed, as ΔG is temperature-dependent. The user discovers a hint in their text that involves using the derivative of ΔG with respect to temperature to find ΔS, leading to a calculation that yields a feasible value for ΔS. There is also a discussion about the units for ΔS, with clarification that it can be expressed in standard units of Joules or Watt-hours. The conversation emphasizes the importance of understanding the relationship between ΔG, ΔH, and ΔS, and how temperature affects these calculations.
Brimley
Hello All,
I've been struggling to figure out how to solve for change of enthalpy and entropy. My reference text makes it look so easy but then gives an example where it provides totally different information. Here is the reference from the text:
"A Lead Acid Battery's measurments were taken at 27 deg C yielding the following data:
Open Circuit Voltage (OCV) = 2.05 V
n = 2
dE/dT = 0.2 mV/K
DeltaG, DeltaH, and DeltaS can be found using Gibbs Free Energy Equation and the formula DeltaG=DeltaH-T*DeltaS."
I have no idea how to find DeltaH or DeltaS given this data!
Here is how I solved for DeltaG:
DeltaG=-nFE=-2(98485)(2.05)=-403/788 J/mol (dived by 3600 s to convert to Wh/mol)
DeltaG = -112.163 Wh/mol
Where can I go from here?
Any and all help is greatly appreciated! --Brim
Chemistry news on Phys.org
If you know E, then you can calculate \Delta G, as you have done already. You also know that \Delta G = \Delta H - T \Delta S. But, this leaves you with two unknowns.
Perhaps you can calculate some more values of \Delta G, and then solve for \Delta H and \Delta S? Hint: they've given you a piece of information that you haven't needed to use yet :)
What do you mean by more values of deltaG ?
Because there are two unknowns, \Delta H and \Delta S, you need more than one value of \Delta G (at least two), to get the solution.
\Delta G = nFE, so you need to work out \Delta G over a range of values of E. Now, what does E depend on?
I don't understand how I would attempt solving for deltaG again once I've already found it. All of its variables are known, so how can I deviate?
Any advice on deltaS and deltaH ?
E (and, therefore, \Delta G) depends on temperature. So work out \Delta G at some different temperatures, and you can solve the equation to get \Delta H and \Delta S
I do not follow this logic.
E is known
Delta G is known
Delta H and Delta S are functions of Delta G (Which is down).
Why find another Delta G? You would find Delta G and Delta G whose delta (difference) seems to be irrelevant.
Perhaps you can provide your proof?
You need to solve the following equation: \Delta G = \Delta H - T \Delta S. You know \Delta G and T, which leaves two unknowns: \Delta H and \Delta S.
You cannot solve for two unknowns with a single equation: you need to have two sets of values. The way to do this is to solve the following set of simultaneous equations, using the value of \Delta G and two different temperatures.
\Delta G_{(1)} = \Delta H - T_{(1)} \Delta S
\Delta G_{(2)} = \Delta H - T_{(2)} \Delta S
The difference between these two \Delta G values isn't negligible- \Delta G is a temperature dependent quantity!
Okay, wait a minute - I found a hint in the text that says to utilize the derivative of deltaG = deltaH - T*deltaS
d \Delta G/dT = - \Delta S
d (nFE)/ dT = - \Delta S
nF * dE/dT = - \Delta S
2(98485)(0.2*10^-3) = - \Delta S
- \Delta S = -39.394
Does that seem feasible?
Yes, that's another way of doing it :)
I lost track of my units, do you have any insite as to what units my \Delta S is in?
You can work that out by looking at the units on the left hand side.
The units of 2F\frac{dE}{dT} are C mol^{-1} V K^-1. Can you simplify that a bit to get the more standard unit?
Hello niallj, I am unable to simplify that unit. I'm supposed to wind up in either Joules or Watt hours.
Can you assist with the conversion process? I wiki'd Joule and Watt (and Watt Hours) for their equivalent units with no luck.
CV is J :)
niallj said:
CV is J :)
So I have J/(K mol) but when I calculated \Delta G I only had units of J/mol --> Wh/mol.
Does this K get canceled out anywhere?
That's right- remember that \Delta G = \Delta H - T \Delta S. So it get's canceled when you multiply entropy by temperature.
How about using Gibbs Helmholtz equation?
