Does Launch Angle Affect Speed at Impact with Air Resistance?
  • Thread starter Thread starter barca12345
    Projectile
The launch angle of an object affects the distribution of its velocity components at impact, with horizontal angles favoring forward velocity and vertical angles increasing downward velocity. When air resistance is considered, a steeper launch angle results in a lower total velocity upon hitting the water due to prolonged exposure to air resistance. However, if air resistance is ignored, the total velocity remains constant regardless of the launch angle, with only the velocity components changing. The impact speed can vary based on the angle when factoring in air resistance, but the difference may be negligible depending on the desired accuracy. Overall, launch angle significantly influences the dynamics of motion and impact speed in the presence of air resistance.
barca12345
Dear physics forum,
If an object is launched from a water slide with an angle theta, would the angle of launch affect the speed of the object right before contact with the landing pool, with air resistance considered?
Thanks.
The launch angle affects how much of the speed will be in which direction. For example, if the launch angle is perfectly horizontal, most of the velocity will be forward rather than downward. Whereas if the launch angle is more vertical, you will go up in the air, and then on the way down you will have more of a downward velocity than before (and so the person would go deeper into the water instead of "running into" the water).
But either way (ignoring air resistance) you will have (about) the same total velocity when you hit the water.If you consider air resistance though, then there will be a lesser total velocity if you have a steeper angle, for the simple fact that you will be in the air (bumping into particles) for a longer time.
The change in velocity due to air resistance could be more or less negligable, though. (Depends on the accuracy you want.)
When air resistance is ignored, the projectile will only be accelerated by gravity. I would think the velocity when hitting the water would then be exactly the same for all angles, only the distribution over the x and z component are depending on the angle.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 21 ·
