B Quotient Limit Law: Find the Value of the Limit
The quotient limit law states that the limit of a quotient equals the quotient of the limits, provided the limit of the denominator is not zero. An example shows that as x approaches 0 for the limit of 2x/x, the result is 2 after canceling x. However, if limits are split and yield 0/0, it indicates an indeterminate form, not necessarily an undefined limit. This means further analysis is required to determine if the limit exists. Three examples illustrate different outcomes for the indeterminate form 0/0, highlighting that limits can vary based on the functions involved.
FS98
The quotient limit laws says that the limit of a quotient is equal to the quotient of the limits.
If we had a limit as x approaches 0 of 2x/x we can find the value of that limit to be 2 by canceling out the x’s.
If we split it up we get the limit as x approaches 2 of 2x divided by the limit as x approaches to of x. That would give us 0/0 so wouldn’t the new answer be undefined?
I must be doing something wrong because I think they should be giving the same answer.
Mathematics news on Phys.org
You omitted an important part of the quotient limit law. The limit for the denominator cannot be zero, otherwise the law is not applicable.
(In addition, both limits have to exist)
Likes FS98
0/0 isn't a number, but the usual terminology is the indeterminate form ##\frac{[0]}{[0]}##, which is just one of several indeterminate forms that can arise from limits.
When you take a limit and arrive at this indeterminate form, it doesn't mean that the limit isn't defined -- all it means is that you can't tell without additional work whether the limit exists.
Here are three examples of the indeterminate form ##\frac{[0]}{[0]}##, all with different results.
##\lim_{x \to 0} \frac {2x} x## -- limit exists and is 2.
##\lim_{x \to 0} \frac {x} {x^2}## -- limit does not exist.
##\lim_{x \to 0} \frac {x^3} x## -- limit exists and is 0.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
