Maximum distance a rabbit can venture if a fox runs twice as fast
  • Thread starter Thread starter some_letters
    Riddle
4 replies · 3K views
some_letters
Through a combination of sight, sound, and smell a rabbit can detect a fox at 60 meters. When the rabbit detects the fox, it runs immediately straight to its hole. If the fox can run twice as fast as the rabbit, what is the maximum distance from its hole that a rabbit can safely venture? Assume that the rabbit escapes if they arrive at the hole at the same time.
2. The attempt at a solution
2x + 60 = x
x = 60
Apparently this is incorrect
Does the question state where the hole is compared to the fox and rabbit. Your result is correct if the rabbit is directly between the fox and the hole. but what if the hole was between the fox and rabbit?
I think I understand now. It would always have to be twice as close to the hole than the fox. A twenty meter radius would ensure the fox is always 40 meters away from the hole.
some_letters said:
I think I understand now. It would always have to be twice as close to the hole then the fox. A twenty meter radius would ensure the fox is always 40 meters away from the hole.
Is "twice as close" the same as "half as far" ?
I think so. why do you ask?
