- 449
When you are in a race car turning in at corner entry, you feel like you're being pushed toward the outside of the turn. Most of us refer to this as the centrifugal force. WRONG. There isn't any force pushing you outward. Centrifugal force is what physicists call a pseudo or a fictitious force, because it doesn't really exist. More specifically, in Newtonian mechanics, the term centrifugal force is used to refer to one of two distinct concepts: an inertial force (also called a "fictitious" force) observed in a non-inertialreference frame, and also the equal and opposite reaction to a centripetal force.
So is the centrifugal force isn't real, why do you feel like there's something pushing you out the right-side window when you make a high speed left turn? The answers lie in Newton's laws of motion. An object going straight will keep going straight unless a force makes it change speed, direction or both. When a driver is bombing down the straightaway and starts to turn, the centripetal force makes the car turn and, because he's buckled tightly into the car, he turns also. The force he feels is because his body is trying to keep going straight. The seat and shoulder straps, lap belt and sub straps tied to the car are all exerting a force on him toward the inside of the turn while he's trying to go straight. The net result is that the driver perceives a force to be acting outward, but it is actually acting inward.
Got it?
The force that makes a car turn is called the centripetal force. Centripetal literally means "toward the center". Imagine you had a rubber ball with a string attached to it. Whirl the ball over your head in a horizontal circle. What makes the ball go in a circle instead of flying away from you is the force the string exerts on the ball, which pulls the ball in a circle.
A race car doesn't have a string attached to make it go in a circle but it does have TIRES. The tires contact the pavement exerting force toward the center of the turn. Engineers talk about lateral force. The lateral force is perpendicular to the direction the car is going at any moment.
The size of the centripetal force is given by multiplying the mass of the car by the speed of the car squared, and then dividing by the radius of the turn.
F= MV2 / R where centripetal force equals the mass of the car, v is the speed of the car and r is the turn radius.
Without going into a lot of math , the faster you go, the more force you need to be able to turn. Tighter turns require more force. Just like Aerodynamics, the force isn't linearly dependent on the speed. If you double your speed, the force needed to turn goes up by a factor of four. If you triple your speed, the force increases by a factor of nine.
pls re-read post # 691 on page 34 on weight jacking.
When a race car goes into a turn three things can happen and two are bad.
1. Tires don’t have enough down force and will slip.
2. Tires have too much down force and will overheat the right front tire and eventually will slip.
3. The car completes phase one turn entry and enters mid turn phase two.
The key to this event is to keep maximum tire contact during the dive and roll. This is why the right front tire goes negative camber and the left front tire goes positive camber in the turn. We want both front tires to carry the same amount of load when turning. This is why we bias the car with left side weight. We purposely offset the weight up to 60% static when we place the car on the weight scales. We do this knowing that this need to be done to counter weight transfer during cornering.
WRONG! No “weight” is transferred. The tires react like weight was transferred but what we are really dealing with is FORCE as described above.
Back to the race car racing down the back straight at 90 MPH. When we go into turn entry phase one we change both speed and direction via the tires. The car wants to continue going straight. The suspension and tires are the only tools we have to deal with this force. During the turning event the body will roll to the right side in the typical left turn. It rolls through the front and rear Roll Centers (RC). Some of the momentum Force is scrubbed off by the coil springs ,ARB (sway bar) and dampers (shock absorbers) compressing and converting the force to heat. Once the body has taken a set the tires are left to deal with the rest of the force. If we look at the post # 691 on page 34, we see the force vectors of straight sideways lateral force shearing the tires and the right front tire contact patch countering the body roll force. If we have the front roll center located too far to the right side we start to lift the left front tire in a jacking effect. If the front roll center is located too far to the left there is not enough leverage angle to counter body roll and the force shears the tire contact patch. Ifin have the front roll center located properly, we have the maximum down force possible to stick the right front tire and provide maximum tire adhesion to counter the force and we beat he other race cars out there. Savvy?
Got it?
