Race car suspension Class
1,801 replies · 927K views
Ranger Mike I’d like your opinion... 2400 lb outlaw late model. Over the course of a couple years still with success and wins I’ve always fought the same issue. Can be throttle tight through the corners. Have great forward bite though. Here’s my question. If I am happy with forward bite and entry would I actually leave the rear of the car alone? Being it’s doing exactly what I want it to do. I need to keep working on the front end to be able to cut and rotate without removing any of the bite the rear has? If this is a possibility would I be focusing more so on lowering roll center? Tire temps are optimal. Double adjustable shocks and I feel like I’m pretty knowleadge in that department as well as Corey and Advanced.. Starting to think it’s a slight geometry change I’m after. Front suspension roll center is centered 2.25 above ground. I forgot to mention we turn left and right on tight tracks!
Thank you
am out of town til friday..are you running dirt or paved track?
good front RC height but is it centered?
pls restate your probelm. When you get on the throttle it pushes at mid turn and out??
Yes sir. These are outlaw late models with leaf spring rear suspension. We run a pull bar as well as 9010 shock. We run them on tight 8 tracks. I’m asking for your opinion as far as if we don’t want to give up any rear grip by stiffening the back to make it turn. Would lowering the front roll center a smidge more maybe help the front of the car be able to cut while still maintaining the level of rear grip? It’s alwahs a slight throttle push through the middle of the corners. As well as when your rounding off the corners picking the throttle back up. I was thinking either lower front roll center a hair or maybe soften front sway bar to allow front of car to get some roll in it?
Thank you
Thank you
I’m sorry I forgot to mention it is pavement!
since you are turning left and right, you have to keep the car pretty neutral and not bias anyone side. you are correct, a lower ft rc will cause more roll and down load the tire more...make sure to check camber build
Thank you sir. I know I have been slowly removing camber gain with raising inner upper a arm points as well as making uppers longer. I’ve been neglecting mapping out the current front end. I will get that done and send you the results. Maybe I’ve got some improvements somewhere I’m not catching! Thank you
Ranger Mike thoughts on stagger We are running a pavement tour type modified. We run a 100 laps on 1/4 and 1/3 oval If I reduce the rear stagger by 1/4 inch instead of 3" it would 2 3/4" and increase cross will that help save the right rear tire for the end?
We need stagger when running a locked differential to minimize the tire scrubbing o n the rear tires. Too little and we are loose, too much and we push.
We minimize the damage by using Nitrogen in place of compressed air. The main reason is the molecules are bigger and will not bleed thru the side walls, the moisture is way less than compressed air that typically has a lot of water content. Remember what happens when you drain the air compressor!
Compressed air will cause more tire growth when heat is applied as the tire warms. Moisture becomes steam and we have more growth than that of Nitrogen. We used to use a vacuum pump form and old refrigerator to suck out all t he air on a late model tire before replacing it with Nitrogen.
When new have a lot of stagger we have a static weight situation where the left rear tire is not in contact with the pavement compared to the right front tire. If we were to scale the car, the left rear would show less weight.Cross weight – wedge, diagonal weight , all the same. Total the right front weight and the left rear weight and divide by the race cars total weight. Shoot for 55% on light Emods, 57% wedge on Sprotsman. On street stock 51 to 52%. Mini stocks – 52% wedge.More wedge keeps the rear end tight on turn entry and improves traction off. We are loading the left rear tire.
Running 58 to 60% wedge will make a three legged race car. Quick on a short 20 lap race but bad set up for 50 lapper. Wedge helps on turn entry and exit but may cause mid turn push. So you need more stagger. More wedge, more the stagger
2018 Indy 500 -rules change took out a lot of down force, lot of late lap spins, Chevy and Honda HP really getting close to each other, lot of drivers sawing the steering wheel late in the race stints, wild and wooley racing
Hey ranger mike.
I have a grand American pro late model.
Springs lf-135 rf-175 lr-175rr-500
Wedge 60.5% 1 1/4 bar - 2 turns
Locked rear end - 3 1/2” stagger
57%left 2830 total
Track 3/8 flat track, tight corners
I’ve been struggling with this car being tight in the center for a while and I believe it’s due to wedge. I believe these cars turn well and was thinking of increasing lr spring rate #250 and reducing wedge to 57% keeping everything else the same.
Thoughts?
Thanks
in airport on way to germany next week
you run a 500# rr spring ??
normally 55 to 57% cross weight is ideal
running 30 lapper with 60% to 58% cross makes for a 3 legged race car. quick the 1st 1/3 of race but fades final 3rd due to too much heat on rf and lr tires
more cross weight means more stagger required.
wedge helps bite on turn entry and exit, stagger helps in the middle
try to get 58% left side
how is rear roll steer?
That’s awesome, Have a safe trip. Thanks for the quick reply.
Yes, I’ve run as low as a #400 and as high as #650 with a #250 lr.
Rear roll centre is fairly high Ls-12” rs- 10.5”
With a 57% cross do you recommend I drop RR spring rate and still add LR spring rate?
Hi Ranger Mike,
Here's a question that I've always wanted answered and maybe you can help
Does the motion ration of the suspension have any impact on the compression rating of the shock for that respective corner or does it only impact the spring rate.
To be a bit more specific:
If we are only racing on Ovals ( pavement ) and we have suspension arms on the right side of the car the are 12" or even 15" longer then the left side arms and we place the same Compression rated shocks IE: #4 compression on both the RF and LF will the compression be softer on the right (vs) the left?
I've asked this question to a few people and as always you get mixed reviews, shoot I even argue with myself on what the right answer would be - HAHA
I anxiously await to hear your response on this one
Thanks again, I appreciate all the help and support you provide us all through this forum
short trac - i still have hard time understanding why you run so high a RR spring? are you trying to replicate the Big BAR SOFT Spring setup?
how did you arrive at this set up?
Garage eng .. will take some writing but should get back later today
btw - forgot to say welcome and thank you for the nice words!
rm
Spring rate is when you compress spring one inch and read the total pounds it takes. 200 # per inch.
Wheel rate is spring rate adjusted by the mechanical advantage of the lever, in this case, the bottom A-arm length. It is the motion rate of the linkage squared.
More specifically stated – Motion rate is the inner pivot point of A-Arm to the spring mounting point divided by the distance from the inner pivot point to the lower ball joint on the A-arm.
Next we calculate Wheel rate but we have to figure spring mount angle, cosines and square up motion rates and see post 17 on page 2. Then we go into Wheel Load rate and square instant centers. Lovely! As with any lever, the longer the leaver, the more mechanical advantage we have. Think tetter totter and the fat kid next door sitting in the seat and you being the fat beer drinking 200 # slob scooted closer to the fulcrum or middle point of the tetter totter. Thus a small kid equals the fat slob thru mechanical advantage. You have a much shorter lever than the fat kid.
Longer levers and A-arms mean less effort required to compress a spring over a set distance. Same with a damper or shock absorber. So given the same spring and shock absorber, but with two lengths A-arms, the longer one will be “softer”.
Hi Ranger Mike,
Pavement racing on a high bite surface, and no banking
If given the choice between increasing left side bias by a large amount ( or ) Widening out the overall wheel base [left to right] which option would you take?
Garage eng- welcome. Please see post 255 page 13, post 264 page 14 post 322 page 17 and post 505 page 26
for the left side % see post 783 page 40
recap - ( not the hobby stock tire) add 4 inch track width will pick up slight amount of cornering ability. You up the Gs from 1.30 Gs to 1.33Gs
Depending on your tires , hard spec tires limit you to 55 to 56% left side weight. Super late model slicks can do 58% before the side bite goes away.
As always i remind all racers to look at camber build, bump steer, ackermann, rear roll steer and know what the chassis is doing and when its doing it.
Know where your front and rear Roll Center is and where it goes on the track (dynamically). Know the COG and what it does.
Thank you for the feedback, I read through all the suggested post and it was very insightful.
I do have one more question for you Ranger Mike: Looking at a Supermodified with solid axles front and rear
" Whats the difference between adding rear steer to a race car (vs) Front Axel Lead?"
It seems to me that regardless if you push the RR back (or) Push the RF forward you are achieving the same results - Right? So what am I missing?
Thank you again for helping us all learn a little more about our cars.
Big difference.
Some Racers lead the RF while others trail the RR. Usually the amount is between 3/8" and 1/2".
Let’s look at the front end and leave the trail arm lead to later.
The advantage to leading the RF is that it will create more of a "caster stagger effect" without having to run as much actual caster stagger.
Typically on a manual steer car you run 1° left side caster and 3° right side (power steering ups this to 1° left side caster and 4° right side.
Putting lead in means you won't have to run as much caster in the RF, and that means you won't have as much LR weight jacking when wheel is counter-steered.
See post 319 page 16
For caster. You see the caster split or stagger is not to steer into the corner easier, it's to assist you when you exit the turn with your counter steer.
I am a big fan of square cars. Everything parallel and square. I like this set up as it is a lot easier to replicate after a crash. Adding lead in means fabrication and extra work.Look at rear roll steer on post 81 page 5, post 116 page 8, post 858 page 43 and post 1200 page 60. Real roll steer is great for dirt cars and can help on paved track cars.Trailing the RR means more static rear steer and means more dynamic roll steer. Now for certain very restricted car classes, let us suppose you were to move the LF geometry back 2 inches. To avoid the wheel base check you would have to make sure you could crank in 2 inch to the left rear trail arm before tech inspection. Let us suppose the rules said no engine set back as measured at the spark plug. Let us assume some sneaky crew chief made access to the right side spark plug a very easy measurement to the top ball joint. The left side required some gymnastics to get a good measurement due to alternator, power steering and oil cooler placement.
Some low life cheating sob could set the whole engine back 2 inch and the car would have more rear weight bias and had a 2 inch shorter left side wheel base. Car would turn left like a bandit and had 52% rear weight bias when everyone else had 49 to 50%. But this would be considered “cheating” in some corners of the {all things are equal} universe.
New member to the forum. I stumble across this forum looking for set-up advice. I've read through this thread a few times and relearned a lot of great info. I raced Street Stocks and Limited Late Models on both dirt and asphalt for 10 years, had some some wins; but had to stopped 10 years ago. Life got on the way. I was told by my wife that we are racing next year so I'm trying to get prepared. Cut my 108" car apart yesterday, shorting it up to 103". Much to do.
I wanted to Thank Ranger Mike and others for keeping this thread going. I'll have some questions in the near future. Thanks again.
Real good hook up on paved track by street stock. Do not like brake lines tie strapped.Stock control arm bushings ‘ worn out” in the right places.
When you are at the track hot lapping, try this to fine tune the car set up. Hot lap at mid speed and note the steering wheels degree of turn at mid track. The mid track is usually marked o the wall. If not, pick a point and use this mid turn location on the wall for reference. You should have the 12 o’clock position marked already for easy of centering. So note the 12 o’clock of the steering wheel when you are at the mid turn wall location. Use a piece of tape to mark it.
Next thing to do is hot lap the car at you best speed and again note the same mid turn location and the new mid turn steering wheel 12 o’clock position. Mark it and make sure you note which was at slow speed.
If the steering wheel hot lap mark is more than the slow speed mark, the car is tight. If the hot lap speed is less that the slow speed tape, the car is loose. Adjust accordingly.
Excellent video on using rear steer to tune. I recommend a total of 1/4 inch wheel base change when first tuning with rear roll over steer. Make sure you have no chassis bind and the rear end remains centered when in dynamic roll.
This is on dirt but nice how the wheel base on the left side shrinks up under power and returns to stock setting off throttle..extreme but a little on paved track will aid turning car mid corner
another view of rear roll over steer on dirt
With the off-season upon us and time to make our cars better, I have a question. I have and will again measure my front to plot out the roll center in hopes of improving our performance. But before I embark on that task I have a question concerning determining the correct center line.
When laying out for the roll center should I use half distance between the frame rails or the midpoint between the tread width. When reading through the posts here I have seen both mentioned but not in a clear manner to understand the correct method. The reason I ask is we have a asphalt modified and not only is the chassis is offset several inches the wheels differ in offset by 2+ inches.
We also have different length lower control arms to compensate for the chassis and wheel offset. I am trying to get the most accurate determination of the roll center and make the car better for 2019.
Thanks in advance
I always used the center line determined from the lower inside A-arm mounts and painted a center line on the bottom of the frame and top at several locations. This was done with the wheels and A-arms off the car when I was going thru the rebuild process annually. I liked to see just how much offset the car really had. Real easy to do if the air cleaner center bolt is sticking up like a flag on Iwo Jima up and the center line is 4 inch to the right of it!
I always put a piece of roll bar foam over the top side marking. Just paranoid crew chief thinking I guess.
Another advantage is the center line travels with you and can be used to rebuild the car at the track if you wad it up. Down side was that a sharp competitor could see this too if he got close enough while the car was in the pits. The Track width method is ok as well but remember to set aside a complete set of tires and wheels marked SET UP so you will have the same set up each time.
Thanks Ranger Mike, To me it was the most logical place but in seeing other references I was wondering if I was ding it wrong. As always great info here to keep referring back to.
Handling diagnosis at the track
Sorting out a just rebuilt or just purchased used race car can be a challenge. It is assumed you can tell if the car is pushing going in, or at mid turn or on exit otherwise you would not be reading this.
One way to determine what is going on is to hot lap the “ new” car. You should have the 12 o’clock position marked already on the steering wheel for easy of centering. If you don’t……shame on you!
Hot lap at mid speed and note the steering wheels degree of turn at mid track. The mid track point is usually marked on the corner wall. If not, pick a point and use this mid turn location on the wall for reference.
Note the 12 o’clock of the steering wheel when you are at the mid turn wall location. Use a piece of tape to mark it.
If the steering wheel hot lap mark is more than the slow speed mark, the car is tight. You are having to turn the tires more at higher speed and almost always will cause a snap loose condition once you are at turn exit.If the hot lap speed mark is less that the slow speed tape, the car is loose. Now some will argue that you can race a loose car but this is dangerous. I maintain you can race a tight car but it will be slow.
So what should you fix first? Cars that are loose on entry should be fixed immediately before even thinking of any other action. Make a single big change to cure the loose in situation. Higher front spring rate or softer rear spring rate.
Swap out the ARB to stiffer one. You can preload the ARB (sway bar) but I hate this arbitrary choice. I try to use the panhard bar adjustment for fine tuning. The same with using less stagger.Cars that are pushing going in need the same large change like going softer on the front spring or stiffer on the rear spring. Use a softer ARB. Cars that are pushing at mid turn will usually be loose off because the car moves up in the groove and is off the best race line and
runs out of room. The car gets loose because of the late exit and driver over reacts to the pit wall growing bigger in the windshield..yikes!I personally view cross weight (wedge) stagger and panhard bar adjust as fine tuning options and recommend these not be used as at the track fixes when you should be changing out the springs. Change out the front spring/springs to cure turn entry problems and use rear spring changes to cure traction off problems.
One tool you must have is a tire pyrometer. See post # 468 on page 24 on reading tire temperatures.
You must keep good records on the tire temps and tune accordingly.
The above scenario assumes you have the springs and wheel weight close to a good set up. For the rookie just getting into the game it can be confusing. Is the car pushing because the front spring is too stiff or too soft?
Each wheel must have a shock travel indicator on it. You can fabricate these easy. But you must be able to tell how much each right side wheel is compressing and each left side wheel is drooping in a turn. So ifin the car is pushing going in and the right front spring only compresses an inch ..the spring is too stiff. If it is compressing 4 inch you got too soft a front spring. Savvy?
Hello, name is jc. I have a question and I’m hoping Someone can possibly answer. There are these new trailing arms for a 3rd link setup. And they are the center pull style that mount to the back side of the rear end housing. A few guys run them and basically say that the forward bite is great. So my question is why is the center pull so much better then the traditional trailing arm mounted with the shock on the bottom, any info will be highly appreciated.
do you have a manufacturer name or website i can look at? I assume you are NOT talking about the top link. you are talking about the traditional truck type trail arms that are made up of threaded tube and two rod ends. And the new style has a spring that compresses built into the trail arm
