Race car suspension Class
1,808 replies · 938K views · last reply
Look amigo, I am trying to help you but you are not taking any advice to heart. i told you back in June, rt ft needs a 1050# spring lft frt needs a 1000# spring lft WITH a sway bar (ARB) which you do not have.
Why in the hel* are your running a left front spring stiffer than the rt ft? Rt frt tire is always the hottest tire temp. Put a 1050# spring in the right front and 1000# spring in lft ft and run it AFTER you fix the RC location to 3 inch rt side offset. Still will not be right due to absence of the additional ARB with additional spring rate ( 220 #) but will get you a whole lot closer to winning.
https://www.google.com/search?clien...ate=ive&vld=cid:5a6efc51,vid:V2f-MZ2HRHQ,st:0
Happy Labor Day 2024.
How about a single piston costing you $ 65,000!
Thats $ 520,000 for 8 slugs..a little out of my racing budget!!
This may not be the right thread for this, but does anyone have any advice on what is the best bearing setup for wide 5 hubs? I was ideally looking for ceramic ball bearings but not seeing much results and was curious if anyone on here could share or recommend something! Thank you in advance!
We ran ceramic bearings on all four corners of the Formula Car. May have been a slight advantage due to less friction but in my opinion not worth the big expense. Metal bearings are a lot more forgiving and last longer. Was a nice thought but no real lap time advantage.
Now if you are going for land speed record at Bonneville over 300 mph or racing a car over 175 mph for hours, then the ceramic bearing will make sense. Less thermal growth than steel (see table). This means the inner and outer bearing race and the ball bearing itself will GROW with temperature. So if the bearing components will grow 0.0001" in size for every 72° F increase, things will get real tight real quick. We have all seen the right front hub of round track cars getting red hot on a long green run. Nascar right front wheels are 1200° F! Brakes play a huge part of this so we have cooling hoses blowing on the brake rotors.
A number of things can alter the radial play during the fitting process. A tight shaft fit where the shaft is slightly larger than the bearing inner ring (often called an interference fit or a press fit) will stretch the inner ring so making it bigger. This reduces radial play by up to 80% of the interference fit. A similar thing occurs if the outer ring is a tight fit in the housing. A difference between the shaft and housing temperatures can also be a problem. If a bearing inner ring gets hotter than the outer ring, it will expand more and reduce radial play. This can be calculated as follows:
Chrome Steel: 0.0000125 x (inner ring temp - outer ring temp °C) x outer ring raceway diameter* in mm.
440 Stainless Steel: 0.0000103 x (inner ring temp - outer ring temp °C) x outer ring raceway diameter* in mm.
* The outer ring raceway diameter can be roughly calculated as: 0.2 x (d + 4D) where d is the bore in mm and D is the outer diameter in mm.
There can also be problems where, for example, the shaft is made of different material to the bearing and housing and expands more due to a different expansion coefficient. In such a case, a bearing with a looser radial play may be needed.
A standard radial play is usually suitable and these bearings are more readily available but, sometimes, a non-standard clearance is recommended. A tight radial play is better for low noise, greater rigidity and running accuracy if the load is purely radial. A loose radial play is preferable for high axial loads as it increases the bearing's axial load capacity. It will also better accommodate misalignment between the shaft and housing.
An 80 mm diameter "loose " bearing ( high load applications) has 0.0007" play built in. Now you can see effect of thermal growth of inner , outer races and the bearings themselves.
nominal bore
C2 (tight)
CN (normal)
C3 (loose)
C4 (looser)
Over
Incl.
Metric .001mm
Inch .0001”
Metric .001mm
Inch .0001”
Metric .001mm
Inch .0001”
Metric .001mm
Inch .0001”
_
0-3
2-13
1-5
8-23
3-9
14-29
6-11
0-3.5
3-18
1-7
11-25
4-10
18-33
7-13
0-10
0-4
5-20
2-8
13-28
5--11
20-36
8-14
24
30
1-11
0-4.5
5-20
2-8
13-28
5-11
23-41
9-16
30
40
1-11
0-4.5
6-20
2-8
15-33
6-13
28-46
11-18
40
50
1-11
0-4.5
6-23
2-9
18-36
7-14
30-51
12-20
50
65
1-15
0-6
8-28
3-11
23-43
9-17
38-61
15-24
65
80
1-15
0-6
10-30
4-12
25-51
10-20
46-71
18-28
80
100
1-18
0-7
12-36
5-14
30-58
12-23
53-84
21-34
Less temperature disfussion ( runs cooler ) , lighter weight per bearing.
Make sense?
Ranger Mike said:
Track Tuning Tips
See post 1419 on page 41 for driver tips
Track tuning
Two things any crew chief better have in the tool box , next to the Rolaids, are Stagger tape and a Tire Pyrometer. Preferably one with a memory that will permit you to take readings and will display three readings per tire.
Tire temperatures are the only real way to tell what is going on and it is empirical. Learn how to use the tire pyrometer and make a habit of doing it correctly. I have a nice techy one that tell you to stab the right front tire inside, middle and outside then move to the right rear tire. The cursor ques you where to take the readings. Insert the sensor needle 1/8 inch into the tire at a 45 degree angle and be consistent. You will be stabbing three places on the tire face. Inside edge ( not on the edge but an inch from the inside edge) the middle and the outside ( not the very outside..,an inch from the outside edge). When taking readings try to do it as soon as the driver comes off the track as these tires cool very quickly. Tune and test day is ideal as you can do it on the track if you are solo ones in that session. Then jack up the car and take tire stagger readings right front first. Record the tire growth and this will tell you about stagger.
The optimal tire temperatures should be in a range of 190 to 240 degrees. On a short track it is normal for the outside edge of the RF tire & the inside edge of the LF to be 5 to 10 degrees cooler. This is because of the way the tires travel down the straightaway. On a larger track with longer straights, this spread will be even further. On an oval, the RF tire will have more negative camber, thus resulting in the inside edge of the tire contacting the track more than the outside edge giving you the higher temperature. On the LF you will run with more positive camber, so just the opposite holds true. While cornering these temperatures should even out if you have the correct amounts of camber & or weight transfer. The more camber you run, the higher these spreads will be. On a small track were you spend a lot of time cornering, you'll find the spread not as high. This is because your spending more time cornering than on the straights, thus distributing the temperatures across the face of the tire more evenly. If you try to achieve even temps across the tire you may develop a push. This is telling you that you have too much positive camber. Although the tire may be flat on the track, on a straightaway, the tire will not be flat on the track while cornering.
The best way to read tire temperatures is to run 10 laps on a particular setup. Read the temps and don't expect to learn everything reading the temps only once. It will take a number of these sessions to sort everything out that is going on with the tires. Make sure you are not locking up the brakes or making any sudden changes in your steering outputs. These will all create erroneous tire temperatures readings.
A tire with too much NEGATIVE camber will show an excessively higher temperature at the INSIDE edges. Lean the top of the tire out to the outside.
A tire with too much POSITIVE camber will show an excessively higher temperature at the OUTSIDE edges so lean the top of the tire in.
A tire that is OVER inflated will have a higher middle temperature than the inside & outside edges.
A tire that is UNDER inflated will have a lower middle temperature than the inside & outside edges.
A car with too much toe OUT will show higher temperatures on both INSIDE edges of the front tires.
A car with too much toe IN will show higher temperatures on both OUTSIDE edges of the front tires.
A RF tire that is HOTTER by more than 10 degrees over the RR indicates a tight PUSH (understeer) condition.
A RF tire that is COLDER by more than 10 degrees over the RR indicates a loose ( oversteer) condition.
A tire with the HIGHEST average temperature is the corner of the car that you should work on first.
A tire with the LOWEST average temperature is the corner of the car that you should work on second.
A RF & LR diagonal average that is the same or higher than the front & right side average indicates too much wedge.
A RF & LR diagonal average that is more than 10 degrees lower than the front average and right side average indicates not enough wedge.
Let’s look at a few examples.
RF
I----M----O
208--202--194
Indicates too much negative camber.
RF
I----M----O
194--202--208
Indicates too much positive camber.
RF
I----M----O
204--188--197
Indicates an under inflated tire.
RF
I----M----O
204--210--197
Indicates an over inflated tire.
RF
I----M----O
204--198--194
Indicates correct camber. Overall average temp is 198.6.
RR
I----M----O
227--225--223
Overall average temp. is 225.
If the RR & RF temp above came off the same car we have a very loose racecar. The RR is 26 degrees hotter than the RF. If this RR is also the hottest tire on the car, it indicates the RR is spinning and or sliding in the corners. We need to go to a weaker RR spring to keep more weight on this tire and prevent the wheel spin. This should cool this tire & tighten up the chassis.
Caution -Temperature Averaging works when you have a fast car and need to fine tune it. If your car is a log wagon and wallowing around like a whale cure the handling first.
Panhard bar
Do not forget- The mid point between the right and left side anchor points on both panhard bar and J bar is the Roll Center. This Rear RC can be offset many inches from the vehicle centerline.
When Panhard bar has chassis mount on frame right side the Rear roll center will DROP under body roll. Opposite if chassis mount on left side.
If you raise both mount points on the Panhard bar, you are raising the Rear RC. The rear roll center will still move downward in body roll as above stated.
Hi RM
Doesn't a weaker spring on any side of the rear make less role couple in the rear, causing less load transfer on the rear and more on the front axle? This would make the right rear lighter not heaver.
Ranger Mike said:
Tie down shock keeps weight on rt ft forever .
I don't think a tie down shock on the right front keeps weight on, infact I think it does the opposite, When brakes and latteral force combine with max load on the rt front the spring compresses as far as it's going to. When it's tied down and some of the load goes away with no braking and some throttle the spring is pushing the axle and the frame apart with near the same force, but the shock is holding the axle and the frame together. The shock is unloading the the force on the axle corner weight equal the spring force minus the frame corner weight, so the resulting useable down force on the axle is the corner weight. Since the corner is compressed, it lowers dynamic cross weight, and should have less load. Do you agree with this theory?
I thought you would like some good news in 2026
So you think we don't make things in the USA any more???
Subject:
US Manufacturing total GDP compared to the worlds GDP , a look at 2014 and today, end of 2025 estimate. ..the 2025 stats are not in yet!
Often when we talk about manufacturing and industry in this country, we talk about loss, decline and shrinking markets. Contrary to much of this type of news, many indicators show that our industrial economy is doing quite well and overall we are still the largest economy in the world.
Recent reports about the USA slipping to number two are based on projections and statistics using weighted methodology and are not accurate. These forecasters of doom and gloom make for comedic reading when you need a laugh.
China And India Will Overtake U.S. Economically By 2075, Goldman Sachs Economists Say
https://www.forbes.com/sites/dereks...goldman-sachs-economists-say/?sh=7642e65a8ea9 Totally WRONG!
Look at the telling data point of how well we’re doing - In 2014 Taken alone, the U.S. Manufacturing GDP would be the 11th largest economy in the world. Today THE UNITED STATES MANUFACTURING GDP $ 2.9 trillion , 8th biggest GDP
Nominal GDP Rankings by Country 2014​
  1. United States $17.6 trillion
  2. China $10 trillion
  3. Japan $4.8 trillion
  4. Germany $3.9 trillion
  5. France $2.9 trillion
  6. United Kingdom $2.8 trillion
  7. Brazil $2.2 trillion
  8. Italy $2.2 trillion
  9. Russia $ 2.1 trillion
  10. India $2.0 trillion
  11. THE UNITED STATES MANUFACTURING GDP $ 2.04 trillion
That’s something to think about the next time you see a doom and gloom article about U.S. manufacturing. Here’s the full world economy visual from CNN Money.
We still make some of the best products in the world. This article from a few years ago gives a top 10 list of things made in USA. https://worldpopulationreview.com/countries/countries-by-gdp
Nominal GDP Rankings by Country 2023​
  1. United States: $28.7 trillion
  2. China: $18.27 trillion
  3. Germany: $4.4 trillion
  4. Japan: $4.1 trillion
  5. India: $3.9 trillion
  6. United Kingdom: $3.5 trillion
  7. France: $3.1 trillion
  8. THE UNITED STATES MANUFACTURING GDP $ 2.8 trillion
  9. Brazil $2.3 trillion
   10. Italy $2.33 trillion
   11. Canada $2.24 trillion
USA MANUFACTURING last year was $ 2.8 Trillion and is still 8th in the world. In 2014 the total annual GDP USA was $7.5 trillion ahead of number two.
Nominal GDP Rankings by Country 2024​
Source - https://www.imf.org/external/datamapper/NGDPD@WEO/OEMDC/ADVEC/WEOWORLD
  1. United States: $30.51 trillion
  2. China: $19.23 trillion
  3. Germany: $4.74 trillion
  4. Japan: $4.19 trillion
  5. India: $4.19 trillion
  6. United Kingdom: $3.84 trillion
  7. France: $3.21 trillion
  8. THE UNITED STATES MANUFACTURING GDP $ 2.94 trillion https://nam.org/mfgdata/facts-about-manufacturing-expanded/
   9. Italy $2.42 trillion
10. Canada $2.23 trillion
11. Brazil $2.13 trillion
USA MANUFACTURING is $ 2.94 Trillion and is still 8th in the world. In 2014 the total annual GDP USA was $7.5 trillion ahead of number two. In 2024 USA is 10.98 $ trillion ahead of number two.
2024 US GDP % growth was for the year - 2.37 percent. USA MANUFACTURING is $ 2.9 Trillion and is still 8th in the world. In 2014 GDP USA was $7.5 trillion ahead of number two. In 2024 USA is 11.5 $ trillion ahead of number two.
Nominal GDP Rankings by Country 2025 End of Year est.​
  1. United States: $30.8 trillion 2025 year to date (Q3) $ 30,331 trillion
  2. China: $19.4 trillion
  3. Germany: $ 5.0 trillion
  4. Japan: $ 4.28 trillion
  5. India: $4.13 trillion
  6. United Kingdom: $3.96 trillion
  7. France: $ 3.36 Trillion
  8. THE UNITED STATES MANUFACTURING GDP $ 3.08 trillion
   9. Italy $2.54 trillion
10. Russia $2.53 trillion
11. Canada $2.23 trillion
USA MANUFACTURING is $ 3.08 Trillion, 8th in the world. In 2014 the total annual GDP USA was $7.5 trillion ahead of number two. In 2025 USA is 11.4 $ trillion ahead of number two.
2025 US GDP % growth was for the year - 3.0 percent 12/28/2024 https://www.atlantafed.org/cqer/research/gdpnow
Rear end camber
The tighter the track the more stagger is needed. A ¼ mile paperclip track means up to 4 inch stagger. That is a lot of camber angle added to a neutral camber rear axle tire.
Both stagger and camber are used together in oval racing to help the car "turn itself" into the corner. Stagger helps the car rotate by making the outside tire travel farther per revolution, while camber ensures the tire contact patch remains flat against the track during body roll.
Rear-end tire stagger—using a larger circumference tire on the right rear than the left—is primarily used in circle track racing to help the car turn left
While not directly causing mechanical suspension camber changes, running significantly different-sized tires on a solid axle can create effective camber that affect the rear tire contact patch.
Adding camber to both rear axle tubes on a solid axle rear end (common in muscle cars, trucks, hot rods, drag cars, or classics like Ford 9", GM 10-bolt/12-bolt, etc.) is a common mod for better cornering grip.
Most methods target 0.5° to 1.5° camber max—more risks axle spline wear, bearing binding, or premature failure (especially on non-floating axles). Full-floating axle conversions allow more camber without burning bearings, excessive spline wear etc.
Per Dave Adams – Chassis Engineering – The alignment and steering characteristics of a car’s rear axel steering can have a dramatic effect on how the car handles and on how well it gets power to the ground. Drive driving backwards and feel how sensitive the car is in reverse gear. It is normal for rear wheel toe-in and camber to change between one and two degrees as the car moves down the road. On circle track cars, left turn only, negative camber on right rear and positive camber on left rear tire is desired.
The shorter tight flat racks need max permissible camber you can run without damaging the splines and bearings.
@Ranger Mike wow one hell of a thread going on here, well done sir. i am hoping that someone can point me in to the right time line as im sure it has been covered here already. I am hoping to find some info on spring rates and expected shock travel for a 3000# ashfault latemodel on a flat (7 deg) 1/4 mile track. We have only been able to achieve approx 1 3/4" shock travel in the front right and that is with 400# fr and 350# fl springs. Driving style is late hard braking into the corner entry, deeper than the rest of the competition so we should be seeing more travel but we just cant seem to find it. are we still too heavy on the spring rates or are we actualy at the max throw that we should expect to see in this car with this config? i guess all the info will help as well, 54.8% left side 47.8% rear, rr spring 350# lr 150# shocks fl 4/10 fr 4/8, rr 5/5 lr 4/6. i dont have corner wieghts off the top of my head here.
Welcome and thank you for the kind words.
From what little info you provided, I say you are close to ideal from the book learning point of view.
Book says springs are lf 350, rt ft 400, lft rear 225, rt rear 250 to 300
ideal weight is 58% left side. 51% rear, 57% cross weight
toe out on 1/4 track is 1/8 to 3/16"
questions, I assume you run ARB or sway bar of 220 lbs.
Did you check for correct Akerman? Absolute requirement on 1/4 mile track
Did you correct bump steer?
these are cheap to fix but take time and matter greatly on the short flat tracks..
it is about keeping max tire contact patch!!!!
what is rear shock travel?
I am a fanatic about your Roll Center height and location, do you know it?
Have you measured the 3rd link mount location on rear end?
good start for that Checker!
Hey thanks for the reply. sway is way too heavy we have a white bar 500# if the book is correct, i will drop that down asap if i can find one quick before the end of hte season. we have zero ackerman, i am planning on putting some in tonight, have to hog out the spindle for a slug as we are not allowed fabricated spindles in our class. Bump steer is as close to zero as possible. rear shock is only about an inch of compression either side, i dont know extension as i dont have the proper travel indicators to measure that. pan hard is approx 9 3/4 both sides (right side to chassis) and front roll is approx 5" left and 3.4" high. 3rd link mount i dont know the height of but we are in the ball park of 13deg and to the right side of the brackets on the diff mount. Rules for weight dist are max 55% left and 48% rear, we ended the night with approx 47% wedge and half round of bar in it, still had a bit of push mid corner but we were working on getting that out. we did pop a spring rubber in the lr spring to bring it up to approx 175#. We have found that this car likes 2" of rear stagger which is contrary to what everyone else is saying, they are all 3-3.5" stagger, when we run that it is spinning the tires all the way out of hte corner and down the straight. any idea why would have that or do we just give the car what it is asking for?
hey there @Ranger Mike any thoughts on the stagger dillema with this buggy?
With that 500 #arb you turned the race car into a 3000 lbs. go kart
very little body roll, very low suspension travel. The ARB or sway bar is way too big at 500#
Roll center location has to be changed so you get down force on right front tire. AND Too stiff ARB (sway bar) is holding body roll down. Fix RC location and 3rd link mount offset location over the winter.
You are forced to run hard spec tires so this whole thing revolves around TIRE Contact patch. I assume the camber build is correct as tire temps will tell you.
RC height is ok but should be 3 inch to right of center so you get more body roll on right ft tire.
This is why you only have 1 inch shock travel. Again the ARB is not permitting body roll to add down force on right side of car on corner entry.
Car spins rear tires because not enough weight on both rear tires. This is because you have too stiff right rear spring. Lighter ARB will let front end lift on acceleration putting weight on rear end for traction.
On flat tracks with hard spec tires you need proper stagger and wedge. Typical stager on flat track with very tight turn tracks is as high as 4 inches.
Try 3 inch stagger. A cheap way to see if it is in right direction.
Ackerman means the lft ft tire turns about 15% more than the rt ft tire. The tighter the turn the more ackerman required. Shoot for right front wheel at 18 degrees and left ft at 22 degrees. Try 3/16 toe out and read tire temps and adjust accordingly.
Panhard bar is level and not helping traction. Angle panhard bar down hill to the rt rear tire to add traction. Start with 1 inch down hill, adjust from there. Another cheap ix to add traction.
excellent, thank you. Ive also purchased the one book that i didnt have that you suggesed in the first post. "Tune to win" very good book so far. Being that we are roundy rounds and not road course its not all applicable but all great info just the same so thanks for pointing me in the right direction there.
Would rear toe out seriously affect drive off traction? i have not had a chance to investigate if the rear axle is bent as of yet. but the last round of testing we did there was zero traction once the gas pedal was touched. It didn't matter the stagger we had we tested everything from 1" up to 3.5" stagger, doesnt matter where in the corner the gas was touched or how hard or soft the pedal was touched. If the driver was attempting to hold any speed through the corner at all then the car would just spin the tires as soon as the power was applied. We lightened up the rr spring to 280# as that is what we had on hand, and dropped the 3rd link to as steep as possible. none of which made any difference. We also dropped the air pressure in the rear to try and see if that would help with rear traction, it helped but only made a very small degree of difference, nothing we changed made enough of a difference to say that it helped at all. IF my suspicions are correct and we have a bent rear housing (ford 9") and we are in a toe out scenario is there any allowable amount of to out we can accommodate for or do we shoot for straight ahead or slightly toe in when we go to straighten it out?
It is always good to check for impact damage. But until you get rid of that massive front sway bar , you will not change the fact that tire spin is due to lack of down force to add traction.
Ranger Mike said:
It is always goo to check for impact damage. But until you get rid of that massive front sway bar , you will not change the fact that tire spin is due to lack of down force to add traction.
ok cool cool thank you. hopefully we can get sway up here before it turns too cold and we have to wait till spring to test. Thanks again.
Change panhard bar angle today!
If you must run #500 sway abr soften it or disconnect it! See photo below.
You are running hollow sway bar I assume. A 1.125" OD 0.125 thick wall tubular bar with 13" long arms( A on pic) = 187 lbs. rating. Same tube arm with 8.75" arm is 415" rating.
Maybe adjust the linkage to the lower A-arm so it takes 1/2" travel until the ARB starts working. A lot of things you can try at the track at no cost.
Read Post # 1660 on page 56..absolute must to cure 3rd link bad location! Must fix over the winter. This cures a lot of tire spin on corner exit.
Fix Ackerman over the winter.
Fix ft roll center offset over the winter. Usually this is longer A-Arm and taller Ball Joint tweak.
excellent thank you again. The sway we did unhook one weekend so it was just along for the ride, that's when we realized we needed lighter springs in it as we were still pushing on exit without the bar. I believe the bar (don't quote me) is 1.375" with 0.125 wall and approx. 12" long arms, either way it is definitely too heavy and we will replace it with a much softer one.
I did mess with the location of the 3rd link with the instructions in #1660 it makes complete sense as to how it affects the car, my question on this one now is does the location on the chassis make a difference in how it works or is that just a central location that we are shooting for on that end?
The pan hard is definitely on my list to adjust especially if we can get out and retest before the snow flies otherwise it will be ready to go for spring .
Ackerman and roll will be worked on and reset over the winter as well, but they are too much to take care of right at the moment as we are currently prepping the shop to insulate and get ready for winter.
The 3rd link should be mounted at percent weight position on rea rend and chassis so the bar is not canted or angled so you have most direct action. You loose force when applied at an angle.
Panhard bar angle if level does nothing for rear traction. When you angle the bar down hill toward rt rear tire you are taking lateral force that just goes sideways and making it push down on right rear tire adding traction.
I used 36" long ARB, 12" arms , 1.375 od, 1.125 ID and got 380# rating, still too big
sway bar calculator
https://www.gtsparkplugs.com/Sway-Bar-Calculator.html
you said - The sway we did unhook one weekend so it was just along for the ride, that's when we realized we needed lighter springs in it as we were still pushing on exit without the bar.
When your race car spins the tires power-on out of a turn but pushes (understeers) when the sway bar is unhooked, a classic case of lack of balance. Unhooking the front sway bar increases body roll and forces the front tires to lean over too much, causing a severe loss of front cornering grip causing a push.
Do not forget, a Push can be because rear tires have too much traction, or front tires are overloaded and traction shear and slide not grip.
Careful now, unhooking that bar increases cross-weight transfer to the rear, which should add rear grip. Which it did as you stated.
BUT, if your chassis is rolling excessively, you are likely unloading the inside rear tire, lifting it, or throwing off your camber geometry, causing the rear tires to break traction and spin under power.
ok lots to take in here for sure. First step will be to fix the heavy sway bar for sure. That makes sense if we are rolling too far and losing contact patch on the front via camber gain which then causes a push scenerio. Now if i understand correctly, if we are rolling too far and unloading the LR BUT not so far as to cause a push (we have sort of fixed the exit push last practice) then we should angle the panhard up toward the right side chassis which will load the LR tire with the body roll? Also assuming we have corrected the 3rd link position..
The excessive body roll unloading the LR tire would track as i have been trying to get the car to roll over further in the corner to try and help the push we had their because it was my understanding that we had the correct springs in the car which was incorrect. That being the case we are likely picking the left rear up too far and that is where the exit spin is coming from.
Thankyou again, there is so much to learn and my knowledge of all of this is very lacking lol. This is the first year that i have had anything to do with any of these cars at this level so its like drinking from a fire hose to try and learn it all as fast as i can.
