Radiative/Convective Boundary Conditions for Heat Equation
sharpybox
Hi everyone,
I'm attempting to create a computer program to solve the transient 3d heat equation using the Crank Nicolson method.
I would like to model the boundaries of my domain as losing heat via convection and radiation due to the temperature difference between the boundary and the air in which the system I am modelling resides, but would like to check i have the correct method for incorporating these modes of heat transfer into my model.
At the moment for each internal node I have the following finite difference scheme:
(1+6\mu)T^{t+1}_{i,j,k} - μ(T^{t+1}_{i+1,j,k} + T^{t+1}_{i-1,j,k} + T^{t+1}_{i,j+1,k}+T^{t+1}_{i,j-1,k}+T^{t+1}_{i,j,k+1} + T^{t+1}_{i,j,k-1}) = (1-6\mu)T^{t}_{i,j,k} - μ(T^{t}_{i+1,j,k} + T^{t}_{i-1,j,k} + T^{t}_{i,j+1,k}+T^{t}_{i,j-1,k}+T^{t}_{i,j,k+1} + T^{t}_{i,j,k-1})
Where T represents the temperature field and \mu = \frac{tα}{2h^{2}} (t = time step, α = thermal diffusivity and h = step size in x/y/z dimensions).
As I understand it this type of boundary condition is a Neumann condition and can be represented by (assuming a 1d case along the x=0 boundary):
-k\frac{\partial T}{\partial x} = hc(T-T_{a}) + \epsilon\sigma(T^{4}-T^{4}_{a})
(hc = convective heat transfer coefficient, k = thermal conductivity, ε = emissivity, σ = Stefan Boltzmann constant, T = node temperature and t_{a} is the ambient temperature.)
Applying a central difference approximation to the derivative at node T_{0,j,k} yields:
-k\frac{T^{t}_{1,j,k} - T^{t}_{-1,j,k}}{2h} = hc(T-T_{a}) + \epsilon\sigma(T^{4}-T^{4}_{a})
T^{t}_{-1,j,k} = \frac{2h(hc * (T^{t}_{0,j,k} - T_{a}) + \epsilon \sigma (T^{4t}_{0,j,k} - T^{4}_{a})}{-k}
Am I correct in thinking that the statement above is then substituted into the original Crank Nicolson FD scheme quoted earlier in place of the T_{i-1,j,k} node for this boundary? Is the method the same when considering the x = maximum boundary when it is the T_{i+1,j,k} node that needs replacing?
And finally is it necessary to repeat the process at the t+1th time step as well as the time t?
Thanks for your help
It is possible to obtain the value of the derivative on the boundary if this is helpful to you.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
