Radiocarbon Dating: Determining Sample Age of 41000-Yrs
  • Thread starter blue_lilly
In summary, the practical limit to ages that can be determined by radiocarbon dating is about 41000-yr-old sample. To calculate the percentage of the original 6 12 C atoms that remains, the equation (N1/No)=e^-λt is used, where t = 41,000 yrs, T1/2 of Carbon = 5730 yrs, and ln2 = .693. After plugging in the values and solving, the correct answer is found to be 0.00702 or 7.0225E-5%, which is calculated by dividing the result by 100.
blue_lilly
36
The practical limit to ages that can be determined by radiocarbon dating is about 41000-yr-old sample, what percentage of the original 6 12 C atoms remains?
(N1/No)=e^-λt
Variables:
t = 41,000 yrs
ln2 = .693
I basically plugged in the numbers and solved because you are given all the variables.
(N1/No)=e^-λt
(N1/No) = e^-(ln2/T1/2)t
(N1/No) = e^-(.693/5730 yrs)(41,000 yrs)
ln(N1/No) = -(.693/5730 yrs)(41,000 yrs)
ln(N1/No) = -(1.2094E-4)(41,000 yrs)
ln(N1/No) = -4.95863
(N1/No) = e^(-4.95863)
(N1/No) = .0102548​
I then calculated for the % because the answer .012548 is a fraction.
.0102548/100 %
=1.025%​
However that answer is incorrect and I'm not exactly sure why. I made sure that I was using the (ln)-function instead of the (log)-function. I don't know if it is my math or if I'm putting it into the website incorrectly.
Any help would be greatly appreciated!
(N1/No)=e^-λt
Variables:
t = 41,000 yrs
ln2 = .693
(N1/No)=e^-λt
(N1/No) = .0102548​
.0102548/100 %
=1.025%​
I get that e(-4.95863) ≈ 0.00702 .
Likes 1 person
You are correct, I must have copied it down wrong.
So then, I would take .00702 and divide by 100 to get the Percentage.
.00702/100 = 7.0225E-5%
This is correct, right?
Isn't 1/10 equal to 10 % ?
You don't get that by dividing by 100 .
Where are you getting the 10% from?
I was dividing by 100 because initially you start out with 100% of the material. Or am I incorrect with that idea?
SammyS was illustrating that diving by 100 does not give the percentage.
What is 0.1 as a percentage? How is it calculated?
What is radiocarbon dating?
Radiocarbon dating is a method used by scientists to determine the age of organic materials up to 41,000 years old. It is based on the principle that all living organisms contain a small amount of radioactive carbon-14, which decays at a predictable rate after death.
How does radiocarbon dating work?
Radiocarbon dating works by measuring the amount of carbon-14 in a sample. When an organism dies, it stops taking in carbon-14, and the existing carbon-14 begins to decay into nitrogen-14. By measuring the ratio of carbon-14 to carbon-12 in a sample, scientists can calculate how long it has been since the organism died.
What types of materials can be dated using radiocarbon dating?
Radiocarbon dating can only be used on organic materials, such as wood, bone, and plant fibers. It cannot be used on inorganic materials like rocks or metals. The sample must also contain enough carbon for accurate dating.
How accurate is radiocarbon dating?
Radiocarbon dating is a highly accurate method for determining the age of organic materials up to 41,000 years old. The margin of error for radiocarbon dating is typically plus or minus 40 years, but this can vary depending on the quality of the sample and the calibration curve used.
What are the limitations of radiocarbon dating?
Radiocarbon dating is limited to samples up to 41,000 years old, as after this point there is too little carbon-14 left to measure accurately. It is also not suitable for dating materials that have been contaminated with modern carbon, such as fossil fuels. In addition, the method is not effective for dating materials that do not contain carbon, such as pottery or shells.
