Rank and Weight of a Riemann Curvature Tensor
Jack3145
Given a Riemann Curvature Tensor. How do you know the weight and rank of each:
R^{i}_{jki}
R^{i}_{jik}
R^{i}_{ijk}
Is the Ricci tensor always a zero tensor for diagonal metric tensors?
The rank of a tensor can be thought of as the number of distinct indices that the tensor has. Thus R^i_{jkl} is a fourth-rank tensor, while the Ricci tensor R^k_{ikj}=R_{ij} is a second-rank tensor. On the other hand, the Ricci scalar R=R^i_i is a scalar quantity and hence a zero-rank tensor.
The weight of a tensor is defined to be the power of \sqrt{-\det g_{ij}} that appear in the tensor.
What tells the weight?
g_{ab}=(1,0,0,0;0,r^{2},0,0;0,0,r^{2}*(sin(\theta))^{2},0;0,0,0,-c^{2}*t^{2})
(-det(g_{ab}))^{1/2} = r^{2}*sin(\theta)*c*t
No. In fact, it's rarely zero. For instance if you replace 1-2m/r in the Schwarzschild metric with s-2m/r where s is a constant ne to 1, the Ricci tensor gets 2 components.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
