Rate of evaporation of a spherical drop
castusalbuscor
The rate of evaporation of a spherical drop of liquid is proportional to its surface area.
Derive R(t) assuming constant density, where R(t) is the radius of the drop as a function of time.
I know that the surface area of the sphere is A = 4 \pi R(t)^{2}
So would I just take the time derivative of the surface area?
Which gives:
\frac{d A}{dt} = 8 \pi R(t)
Some how this seems wrong.
For this problem you need the volume of a sphere, and the area of a sphere. Now, what does it mean if the "rate of evaporation is proportional to its surface area". Also, assume that as the drop evaporates, it is the VOLUME that is changing. i.e. dV/dt = ? (look at the statement in quotes). Now do you know what to do? You'll need to use the chain rule too.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
