Ratio of Excited Neon Atoms in 5s compared to 3p
The discussion focuses on calculating the ratio of excited neon atoms in the 5s state compared to the 3p state at thermal equilibrium using the Boltzmann distribution law. The formula involves the energies of the states and the Boltzmann constant, yielding a ratio that is extremely small, indicating that nearly all neon atoms are in the 3p state at 300 K. Participants point out arithmetic mistakes in the calculations and emphasize the importance of careful unit management and correct formula application. The conversation highlights the need for clarity in questions posed and encourages double-checking work for accuracy. Overall, the conclusion reinforces that at 300 K, virtually no neon atoms occupy the 5s state.
jjson775
A large number of neon atoms are in thermal equilibrium. What is the ratio of the number of atoms in a 5s state to the number in a 3p state at 300 K? The energies of these states, relative to the ground state are E 5s = 20.66 eV and E 3p = 18.7 eV.
n5s/n3p = e ^-(E5 - E3)/kT
"The ratio of the number of atoms in different energy states at thermal equilibrium can be calculated using the Boltzmann distribution law. The formula is:
N2/N1 = e-(E2-E1)/kT
where:
N2 and N1 are the number of atoms in the 5s and 3p states respectively,
E2 and E1 are the energies of the 5s and 3p states respectively,
k is the Boltzmann constant (8.6173 x 10-5 eV/K),
T is the temperature in Kelvin.
Substituting the given values:
N5s/N3p = e-(20.66 eV - 18.7 eV)/(8.6173 x 10-5 eV/K x 300 K)
N5s/N3p = e-1.96/0.02595
N5s/N3p = e-75.53
This ratio is extremely small, essentially zero for all practical purposes. Therefore, at 300 K, virtually all of the neon atoms will be in the 3p state, and almost none will be in the 5s state."
Found in less than 30 seconds using ck12.org/flexi (free access) :)
Thanks. I worked it in Joules and found my arithmetic mistake.
jjson775 said:
Homework Statement: A large number of neon atoms are in thermal equilibrium. What is the ratio of the number of atoms in a 5s state to the number in a 3p state at 300 K? The energies of these states, relative to the ground state are E 5s = 20.66 eV and E 3p = 18.7 eV.
Relevant Equations: n5s/n3p = e ^-(E5 - E3)/kT
What is your question? Are you asking us to check your work? Is that because it doesn’t give the answer you expect?
You need to be clear about what your are asking and it helps us to know why you are asking it.
Here are mistakes I spotted in your work. (There might be others.)
The expression ##e^{\frac {-(E_x – E_0)}{kT}}## makes no sense. Presumably you mean ##e^{\frac {-(E_5 – E_3)}{kT}}##.
##3.310 \times 10^{-18} - 2.996 \times 10^{-18}## is not ##0.335\times 10^{-18}##.
Your incorrect value of ##0.335\times 10^{-18}## divided by ##4.143 \times 10^{-21}## does not give ##8.06##.
The message is to check arithmetic carefully. Also, units are missing in various key places.
It's worth noting that you could simplify the arithmetic by looking-up and using the value of the Boltzmann constant (##k##) in units of eV/K.
Edit. Didn't see your Post #3 until after I'd posted.
Correct. I was not used to using the Boltzmann constant in EV.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
