How can the rationalized numerator be simplified?
  • Thread starter Thread starter r0bHadz
The discussion revolves around simplifying the expression \(\frac{\sqrt{2x+3}+1}{4}\) and reconciling two different results. The initial simplification leads to \(\frac{x+1}{2\sqrt{2x+3}-2}\), while the expected answer is \(\frac{x+1}{2(\sqrt{2x+3}-2)}\). Participants agree that the discrepancy may stem from a misunderstanding of the denominator's structure. There is speculation that the instructor may not have intended for parentheses to be placed after the first two terms in the denominator. The conversation concludes with a consensus on the potential sources of confusion regarding the expression's formatting.
r0bHadz
\frac {\sqrt{2x+3}+1}4
\frac {\sqrt{2x+3}+1}4 * \frac {\sqrt{2x+3}-1}{\sqrt{2x+3}-1} = \frac {2x+3-1}{4\sqrt{2x+3}-4} = \frac {2x+2}{4\sqrt{2x+3}-4} = \frac {2(x+1)}{2(2\sqrt{2x+3}-2)} = \frac {x+1}{2\sqrt{2x+3} -2}
but doc. Lang is telling me the answer is \frac {x+1}{2(\sqrt{2x+3}-2)}
How did he come to this result??
Yes, you are correct.
Thank you no more discussion is needed. I'm going to assume Lang didn't intend for there to be "(" after the first two in the denominator
... or he intended the denominator to be: ##\ 2(\sqrt{2x+3\,} -1)\,. ##
True that.
