Re: carbon steel - Is a crystal the same as a grain?
392hemi
I'm still a little confused about crystals and grains. Does a crystal become a grain as the metal solidifies?
I'm also not clear on molecules. For instance with a body centered lattice you have nine atoms. One on each corner and one in the center of the body. So within that lattice -- what determines what a molecule is? Sorry -- I'm sure that's a dumb question.
In a body-centered crystal, each atom on the corner is only counted as 1/8, or in other words is part of 8 unit cells. Go back to your solid state physics book and reread that chapter.
As for the grain problem, I do not know. Anyone else? I'd also like to know.
dt
dt
Sorry -- I've never seen a solid states physics book, much less read one. :smile:
I know very little about physics -- I'm just searching for a little info regarding a specific area of metallurgy. At first, I didn't understand what you meant by 1/8 -- but after thinking about it -- I remember seeing the illustrations of the corner atom cut to an eight and it finally dawned on me. Then I found this web site, which cleared if up with an animated illustration:
http://www.kings.edu/~chemlab/vrml/bcc.html
However, I still don't understand what makes up a steel molecule.
Thanks,
Terry
392hemi said:
"...I still don't understand what makes up a steel molecule."
There's no such thing as a "steel molecule". I'm not sure what the exact definition of a molecule is, but this one should work in almost all cases: For a substance to be made of molecules (a localized group of 2 or more atoms) the vapor phase (or at least the liquid phase) of the substance has to be made of those molecules. This rules out steel because when its heated, the Fe, C and any other atoms that its made of come apart long before they all melt. In fact, it rules out all metals and alloys that I can think of as well as most of the elements (exceptions are O2, N2 etc.).
Thanks,
Terry
http://er6s1.eng.ohio-state.edu/mse/mse205/lectures/chapter3/chap3.pdf
This site has some background on crystal structures, and why these "grains" are only in polycrystalline materials.
Keep in mind the advise that was given that you do really need to look up a solid state physics text, because the question involved here are the ones covered and answered in a typical solid state physics class.
mmwave said:
This fits well with my understanding of metallic bonding - the nuclei are surrounded by a 'sea' of electrons so there is no 'molecule' to identify, just a repeating pattern of nuclei sites (the unit cell). Basicallly, the concept of molecule has no meaning for metallic bonding. It's useful for covalent & ionic bonding however. A sodium & a chlorine atom make a 'salt' molecule but two iron atoms don't make a metallic unit cell.
Yes, this is a perfectly acceptable model - to the first approximation. Keep in mind that "metallicity" can sometime be a rather vague definition. What you described as your understanding of metals is perfectly valid for the "conventional" metals that obey the straightforward band structure model. However, for metals (or more accurately, conductors) that are actually doped insulators, such picture breaks down severely. In that case, you CAN have "molecules" as the material making up the conductor - the Cu-O molecules in the cuprate superconductors for example.
Zz.
I'm sure glad I asked.
I have stacks of books on metalworking, welding and metallurgy. Many of them have mentioned "molecules" when discussing metal. I'm writing a book on hand shaping metal and I wouldn't want to make the same mistake.
