Differences Between Real and Complex Spherical Harmonics in Signal Rotation
Real spherical harmonics (SH) are derived from complex SH by taking the real or imaginary parts of the complex functions, which are products of associated Legendre polynomials and complex exponentials. The orthogonality relations differ slightly between the two, with real SH normalized differently, typically by a factor of 1/√2. For transforming matrices between complex and real SH, a transformation matrix can be used, but care must be taken to ensure the correct application of the transformation. When expanding signals using real SH, the method is similar to that of complex SH, but specific adjustments may be needed for coefficients. Understanding these differences is crucial for accurate signal rotation and representation in spherical harmonics.
Cunicultor
Viva!
I wonder if anyone could explain me the difference between real spherical harmonics (SH) and complex SH.
What's the difference in doing an expansion in either situations?
And what are the orthogonality relations for each case?
Any help would be great...( websites, books..)
Cheers:smile:
Mathematics news on Phys.org
The complex spherical harmonics are simply the product of the associated Legendre polynomials and a complex exponential, i.e.
Y_l^m(\theta ,\phi) = P_l^m(\theta)e^((im\phi)).
Look in any math methods text, they should be listed with all of their properties. The real shpeherical harmonics are defined as the real or imaginary parts of these. They have slightly different orthogonality properties.
Hope that this helps some
dt
Cheers!
But what I was really looking for were those orthogonality relations for the Real SH.
I've been looking in "Arfken" and also in "www.wolfram.com", but I didn't get much.
Look in Morse and Feshbach, they have them. The orthonormality relationships are the same, maybe a factor of two different, I can't remember, I used them in my dissertation a few years ago and have not used them since. It is simple to derive anyhow, just the product of the Associated Legendre polynomials and trigonometric functions, should only take a few minutes to do.
dt
I've got the Morse and Feshbach book just here. There's nothing there that can help. Anyway, I've just derived myself the orthogonality relations; it's true, they are diferent by a scale factor from those for the complex SH. I just wanted to know if it is correct.
Please take a look at this, and see the way he defines the real SH.
http://jilawww.colorado.edu/www/sro/thesis/redfield/appA.pdf
What do you think?
That .pdf file is correct. In general, the normalization is different by a factor of \frac{1}{\sqrt{2}}. The real functions are also normalized to 1 anc can be seen from the definition in the .pdf file.
Glad I could help you out.
dt
Hello everybody,
I bring this old topic to life, because I would like to convert a matrix expressed in complex spherical harmonics (Y_{lm}) into a matrix expressed in real spherical harmonics (S_{lm}). I have found here http://www1.elsevier.com/homepage/saa/eccc3/paper48/eccc3.html"
the transformation matrix C^{l} between Y_{lm} and S_{lm} for a given l.
Is it just a similarity transformation that I have to do in order to get the new matrix? I mean:
M_{real}=C^{-1}M_{complex}C
M_{complex}=C^{-1}M_{real}C
I want to be sure that I do this transformation in the correct way, because the results are not the ones that I am expecting :)
Thank you!
Hi everyone,
I need help with SH. My intention is to rotate my signal by using spherical harmonics. I have already everything made. But I am using Real Spherical Harmonics, and I am not pretty sure if for doing the expansion (also the coefficients of the transformation) I have to do this exactly like with Comlpex SH or there is another way.
With Complex SH it was Flm=int(Signal(theta,phi)*Ylm(theta,phi))
Thankss
