Rearrange Formula: 2/(x-2) + 2/(x+2) = 1/2 to Ax2+ Bx + C = 0
  • Thread starter Thread starter Natasha1
    Formula
The equation 2/(x-2) + 2/(x+2) = 1/2 needs to be rearranged into the form Ax^2 + Bx + C = 0. The initial attempt resulted in -x^2 + 8x + 4 = 0, which was confirmed as correct with the caveat that the highest power coefficient should be positive, leading to the equivalent x^2 - 8x - 4 = 0. It's important to note that x cannot equal 2 or -2 due to division by zero in the original equation. Both forms of the equation are equivalent and yield the same solutions, despite appearing different.
Natasha1
1. Rearrange the following equation
into the form Ax2+ Bx + C = 0
I did it and got -x2 + 8x + 4 = 0
Am I correct please?
Could you please show your step-by-step work? That will make it easier for us to check it.
Likes FactChecker
Looks good to me. You should usually show your work in step-by-step fashion. Trying to do too much in your head is slow and error-prone.
Likes berkeman
See picture attached for working out
No, your final equation in incorrect. Start again, and this time do it the easy way: re-write ##2/(x-2) + 2/(x+2)## by putting both terms over a common denominator. I really could not figure out what you were trying to do in your original working, but whatever it was produced errors.
Likes berkeman
Where am I going wrong... I need to rearrange the following equation 2/(x-2) + 2/(x+2) = 1/2 into the form Ax2+ Bx + C = 0
Here's my work:
2 + 2(x-2)/(x+2) - (x-2)/2 = 0
2(x+2) + 2(x-2) - (x-2)(x+2)/2 = 0
4(x+2)+4(x-2)-(x-2)(x+2) = 0
4x+8+4x-8-(x2 - 2x+2x-4) = 0
8x-x2+4 = 0
-x2 +8x+4 = 0
I think that your answer is correct ... with two caveats.
1) Always keep track of values of x that are invalid: x=2 or x=-2 cause a divide by 0 in the original equation. So always add the constraints x≠2; x≠-2. (Click on the 'Σ' button at the top of the entry window to get the '≠' symbol, among others.)
2) Use clear notation for the exponent 2. If you do not have superscripts, type x^2. (On the web site, click on the 'x2' button at the top of the entry window to get superscripts.)
So your final equation should look like:
-x2 +8x+4 = 0; x ≠ +2; x ≠ -2
Likes Natasha1
Here's my work:
8x-x2+4 = 0
-x2 +8x+4 = 0
Sorry: I missed the minus sign in front of your x^2 term, so ##x^2 -8x - 4=0## IS correct. You wrote it as ##-x^2 + 8x + 4 = 0##, but the usual way of writing polynomial equations is to have the coefficient of the highest power of ##x## being positive (so with ##+x^2## instead of ##-x^2##).
Likes Natasha1 and FactChecker
I'm sorry thank you for the advice
Likes FactChecker
Why is it then I get two different solution for both equations -x^2 + 8x +4 = 0 and x^2 -8x - 4 = 0 ?
They are not two different equations! If ##x^2 -8x-4=0## then also ##0 = -0 = -(8x^2 -8x-4) = -x^2 + 8x + 4##.
OK, I guess you could say they are different, just as ##5x^2 - 40 x - 20=0## looks different; but they are all just simple multiples of each other, and they all have exactly the same solutions.
@Natasha1 ,
Thus they are called equivalent equations .
