Rearranging Formula: Make e the Subject | 10b + 5be - 3e + 7c
  • Thread starter Thread starter Gringo123
    Formula Rearrange
To rearrange the formula 10b + 5be - 3e + 7c to make e the subject, the initial equation must be clearly defined. The correct rearrangement leads to e = (7c - 10b) / (5b - 3), but parentheses are essential for clarity. If the first line is treated as an equation set to zero, the subsequent steps would need adjustment, resulting in e = (-7c - 10b) / (5b - 3). Proper formatting and understanding of the equation's structure are crucial for accurate manipulation. Clarity in the initial equation is necessary for correct rearrangement.
Gringo123
I need to rearrange this formula to make e the subject. Have I done it correctly?
10b + 5be - 3e + 7c
10b + 5be - 3e = 7c
5be - 3e = 7c - 10b
e(5b - 3) = 7c - 10b
e = 7c - 10b / 5b - 3
You're not starting with an equation! Without the first line below being an equation, you can't solve for anything.
Gringo123 said:
10b + 5be - 3e + 7c
10b + 5be - 3e = 7c
5be - 3e = 7c - 10b
Assuming that this is your starting equation -- 10b + 5be - 3e = 7c -- your work following it is fine, EXCEPT that you need to use parentheses. You should write e this way:
Thanks a lot Mark
Well if we assume that the first line is an equation (set equal to zero): 10b + 5be - 3e + 7c=0, then the second line changes:
10b + 5be - 3e = -7c, and that would change the rest of the steps which follow...
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
