Rearranging Formula: Solving for Vw
  • Thread starter Thread starter XxphysicsxX
    Formula
To solve for Vw in the equation Fd = (Vw / (Vw - Vs)) fs, it's essential to avoid incorrectly canceling terms. The user initially attempts to manipulate the equation but mistakenly treats VwFs as separate when they should be considered together. The correct approach involves keeping VwFs intact while rearranging the equation. Utilizing algebraic rules, such as factoring and distributing, will help in accurately isolating Vw. Following these guidelines should clarify the steps needed to successfully rearrange the formula.
XxphysicsxX
how do i rearrange for Vw??
I just end up canceling the Vw's when I solve it...
Thanks in advance
the formula is:
(Fd)= [(Vw) / (Vw-Vs)] (fs)
Mathematics news on Phys.org
Can you write out your working and show how they cancel out? That way someone can help you see if you made a mistake in your algebra.
i get:
Fd (Vw- Vs) = VwFs
Fd( Vw-Vs) - Vw= Fs
and i don't go ant further since the first Vw is a possitive and the second is a negative... meaning they'll cancel each other out..
dont know what I am doing wrong!
When you have two terms multiplied together, such as VwFs, you can not simply split them up like you have done:
Fd (Vw- Vs) = VwFs --> Fd( Vw-Vs) - Vw= Fs ... incorrect
Fd (Vw- Vs) = VwFs --> Fd( Vw-Vs) - VwFs = 0 ... correct
You have to consider them a lumped package when you move them around, essentially you have subtracted VwFs from both sides of the equation. If you only subtracted Vw from both sides of the equation you would get:
Fd( Vw-Vs) - Vw = FsVw - Vw
And this doesn't help you too much.
What you can do is keep in mind the foremost rules of algebra:
a ( b + c ) = ab + ac which is the same as ab + ac = a ( b + c )
Try using this rule to expand and/or factorize the equation and see if you can rearrange it that way.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
