Exploring the Natural Value of the Speed of Light
In summary, the speed of light is an arbitrary value that was chosen by our universe. It is not infinite, and can only have one finite speed.
Pjpic
235
Is there a reason that c has that particular value?
Is there a reason that it should have some other value?
Precisely
Because it was created to have that value, with 1 meter.
It seems to be a fundamental built in property of our universe.
The value comes out of maxwell's equations from the permeability and permativity of free space - although in practice it's easier to measure the speed of light and calcualte the permeability and permativity from that.
In practical terms the experimental value of the speed of light is so well known that it is fixed and the length of the meter changes as new measurements are made.
That makes sense -thanks
Or in other words, "The reason c has the value it does is http://www.bipm.org/en/si/si_brochure/chapter2/2-1/metre.html" "
I may have not been clear. I was looking for why c is a particular speed (?) not how the measurement scale is calibrated.
It seems to be an unknown as to why light travels at the speed it does.
In theory, how do we come up with the permeability and permativity of free space?
I think the question is why is it that the universe chose 3E8 m/s seemingly arbitrarily as the speed limit of the universe as apposed to so 4E8 or something even larger (or presumably smaller). So what makes that speed more special than another?
I don't think that there can be an answer to that question. It is just an axiom of nature.
In this question it is not c but the meter and the second that are arbitrary. In fact they have always been recognised as very arbitrary. You can have physical things that are less arbitrary however. A resonant frequency of the Cs atom for instance for time. (Then that is multiplied by a number that gives a time near that of the old second). As for m , well meters are defined by how far light travels in a second! (multiplied by a number to give something like the old meter).
Now for the theory of these less arbitrary things, it is e.g. the resonant frequency of Cs that is the less fundamental and is explained by some theory in terms of c and other fundamental constants, not the other way round!
So really for explanation of c, barring surprises, all it makes sense to ask is whether it can be explained in terms of other fundamental constants like h or you might hope one day, mathematical ones like pi or sqrt(5).
That is the philosophical (epistomological) part; for the answer to this reformulated question I would have to turn you over a physicist who knows what he is talking about,:biggrin: but AFAIK the question is sometimes asked but has never yet been answered.
no. All of these things are contrived. I don't think that the question is about applying some sort of measurement to it but rather something more abstract. Let me try and phrase it this way:
The speed of light is not infinite. It does in fact have a finite speed. That being said, it can only have one finite speed. Why choose the speed that it did? If the speed was different, wouldn't everything else just change in relation to that?
If light has a definite "maximum" speed than the magnitude of the number simply depends on our choice of units that we use to measure it. In other words, the speed of light is only "3 x10^8" if we measure the speed in meter/seconds. In fact, the maximum speed of light CAN be any "number" we wish it to be if we just decide on new units to use to measure length and time. So there is no significance to the "number" of 3x10^8 itself other than that the speed of light happens to come out to that when we decide to measure length with a meter and time with a second. I think a few other people in this thread mentioned this point already but just didn't go into it.
Another question is why does light have any finite maximum speed at all? Or does it in fact have a finite maximum speed might be another question? Apparently some calculations in QED when light is diffracted for example do not give correct answers unless small probabilities are taken into account for light going slightly faster than 3x10^8 m/s.
The number of the speed of light obviously depends on the units we use. Slightly complicated because for practical reasons the metre is now defined in terms of the speed of light.
The speed of light does have a 'natural' value in terms of other fundamental constants such as permeativity/permeability which link things like the charge on the electron to the units of length and time. It might be possible that in a different universe the speed of light was different and all these other constants were also changed to the new value - of course this might mean that there is no difference to this universe - all the changes cancel out if you like!
It is likely that you could not have a different speed of light with the other constants being the same - the result would likely be that atoms couldn't form or instance. This gets into the anthropic argument that the reason for the current constants is that it's the only set of values which allow us to exist and measure them.
1. Why is the speed of light, c, considered a universal constant?
The speed of light, c, is considered a universal constant because it is the speed at which all electromagnetic radiation travels in a vacuum. This means that no matter where you are in the universe, light will always travel at the same speed. It is also a fundamental constant in Einstein's theory of relativity, which has been extensively tested and proven to be accurate.
2. How was the value of c determined?
The value of c was first determined by the Danish astronomer Ole Rømer in the 17th century using observations of Jupiter's moons. Later, it was more accurately measured by the French physicist Armand Fizeau in the 19th century using a rotating toothed wheel and a beam of light. Today, the most precise measurement of c comes from experiments using lasers and atomic clocks.
3. Why is c approximately equal to 3 x 10^8 meters per second?
The value of c is approximately equal to 3 x 10^8 meters per second because it is defined by the International System of Units (SI) as the exact speed at which light travels in a vacuum. This value was chosen to make calculations and measurements easier, as it is a round number and can be easily converted to other units of measurement.
4. Does the value of c vary in different mediums?
Yes, the value of c does vary in different mediums. It is a constant in a vacuum, but it decreases when light travels through a medium such as air, water, or glass. This is due to the interaction between the light and the molecules in the medium, which causes the light to slow down.
5. Can the value of c ever change?
According to our current understanding of physics, the value of c is a fundamental constant and cannot change. It is a key component in many fundamental equations and theories, such as Einstein's theory of relativity and the famous equation E=mc^2. However, some theories, such as string theory, suggest that c may have varied in the early universe. This is still a topic of ongoing research and debate.
  • Other Physics Topics
