Reasoning and Writing Question, what's your interpretation?
The discussion revolves around formulating an equation to calculate a student's total score on a 30-question math exam, where correct answers score 4 points, incorrect answers deduct 1 point, and blank answers score 0 points. The initial equation proposed is 4n - 1m, but it is clarified that this does not represent a ratio of total points earned to total points possible. The correct approach involves expressing the score as a ratio, specifically 4n - m : 120, where 120 is the maximum possible score. Participants emphasize the need for clarity in presenting the equation as a ratio rather than an equality. The conversation highlights the importance of accurately interpreting the problem requirements.
PotentialE
A student takes a 30-question mathematics exam on which she got n questions correct and m questions incorrect and left k questions blank. If correct answers are worth 4 points, incorrect answers are worth -1 points, and blank answers are worth 0 points, write an equation to describe the student's total score as a ratio of total points earned to total points possible.
anything you can come up with! it's a logic-based question and they accept many different answers.
what I would think, is that since there are 30 question, and if you get them all right you'll get 4 points each, meaning you'll get a 120 if you get a perfect score.
so the equation I came up with is:
4n - 1m + 0k = 120
4n - 1m = 120
any other suggestions? does this answer all parts of the question? looking for clever responses...
4n - 1m + 0k = 120
4n - 1m = 120
Setting it equal to 120 is not a ratio.
yeah that's a typo, on my paper i have a colon
4n - 1m : 120
Do you have any reason to believe your answer is insufficient?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
