Recognizing a product of two 3d rotations (matrices)
AA1983
Hi, I have a problem identifying some 3d rotation matrices. Actually I don't know if the result can be brought on the desired form, however it would make sense from a physics point of view. My two questions are given at the bottom.
\mathbf{s}=\left(<br /> \begin{array}{c}<br /> s_{x} \\ s_{y} \\ s_{z}<br /> \end{array} \right),\; \mathbf{S}=\left(<br /> \begin{array}{c}<br /> S_{x} \\ S_{y} \\ S_{z}<br /> \end{array} \right)
H=\left[\left(<br /> \begin{array}{ccc}<br /> 1-\left(1-C_{z}^{2}+C_{x}^{2}\right)\gamma^{2}&amp; 0 &amp; -2\gamma\left(1-C_{x}C_{z}\gamma\right) \\<br /> 0 &amp; 1-\left(1+C_{z}^{2}+C_{x}^{2}\right)\gamma^{2} &amp; 0 \\<br /> 2\gamma\left(1-C_{x}C_{z}\gamma\right)&amp; 0 &amp;<br /> 1-\left(1+C_{z}^{2}-C_{x}^{2}\right)\gamma^{2}<br /> \end{array} \right) \mathbf{s}\right]\cdot\mathbf{S}<br />
(this describes Kondo effect in a quantum dot with spin-orbit interaction)
The goal is to bring H on a the form H = \left(\mathbf{A}\mathbf{s}\right)\cdot\left(\mathbf{B}\mathbf{S}\right) where A and B are matrices describing rotations.
For Cx=Cz=0 :
H=\left[\left(1-\gamma^{2}\right)\underbrace{\left(<br /> \begin{array}{ccc}<br /> 1 &amp; 0 &amp; \theta \\<br /> 0 &amp; 1 &amp; 0 \\<br /> -\theta &amp; 0 &amp; 1<br /> \end{array} \right)}_{R_{y}(\theta)+O(\theta^{2})}<br /> \mathbf{s}\right]\cdot\mathbf{S} \;\; \approx \;\; \left(1-\gamma^{2}\right)\left(R_{y}(\theta) \mathbf{s}<br /> \right)\cdot \mathbf{S} \;, \qquad \theta=\frac{-2\gamma}{1-\gamma^{2}}<br />
That is, H is a vector product between spin S and a spin s that has been rotated around the y-axis with angle theta.
For Cx and Cz different from 0 :
In this case the matrix cannot be direct identified as a rotation around the x,y or z axis. The questions are now:
1) can it be a rotation around another axis?
2) Is it possible to write it as H = \left(\mathbf{A}\mathbf{s}\right)\cdot\left(\mathbf{B}\mathbf{S}\right) where A and B are matrices describing rotations?
I would be glad if anybody has an idea about how to deal with this.
You essentially have written that H = \mathbf{s}_1^T \mathbf{D} \mathbf{s}_2, and the question is whether you can write \mathbf{D} = \mathbf{A} \mathbf{B}, where A and B are rotation matrices. Now, rotation matrices form a group, hence \mathbf{D} should also be a rotation matrix. Is \mathbf{D} orthogonal? I'm assuming it is.
Anyway, there isn't a unique way of writing D as a product of two rotations. One is to take A = D and B = identity. Maybe I've misunderstood.
One of the real eigenvectors of the matrix is the y unit vector, so if it is a rotation matrix it can only possibly be a rotation about the y-axis. If it is a rotation matrix, the corresponding eigenvalue
1-\left(1+C_{z}^{2}+C_{x}^{2}\right)\gamma^{2},
must be equal to 1. This can only happen if \gamma = 0. So except in this presumably trivial case, no, it is not a rotation matrix.
Dave
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
