Recurring decimals in prime fractions
  • Thread starter Thread starter Oxymoron
    Fractions Prime
Oxymoron
When I write out the decimal expansion of 1/p where p is a prime, it is always a recurring decimal with a period per(p). I was thinking why inverting a prime number should always give a recurring decimal but could not think of a reason other than it has to be something to do with our base 10 system of counting.
Some prime reciprocals, such as 1/7, 1/17, and 1/19 have periods which is one less that the prime. That is, per(p) = p-1 for some primes. And in fact, for all primes p, per(1/p)\,|\,(p-1). These are all interesting but there is something which I can't seem to explain.
Take the prime 11. Then the period of 1/11 is 2. Take some other prime p. Then
per\left(\frac{1}{11}\times\frac{1}{7}\right) = 2per\left(\frac{1}{p}\right)
so long as p < 31.
After looking at 1/11, I started looking at other prime reciprocals, hoping to find other relationships between the periods of 1/p, 1/q and 1/pq. Unfortunately, the only thing I could find was that
per\left(\frac{1}{p}\times\frac{1}{q}\right) = \infty
whenever p=q and the period of 1/p is odd.
I was hoping for a nice clean relationship between 1/p,1/q, and 1/pq but I could not find one at all. So I tried checking the web and again, no one seems to have found any relationships. So I came here. If anyone has seen, or done any work on comparing periods of different prime reciprocals, could you please share your knowledge.
Cheers.
These, and the relation you want for 1/pq, can be explained by the relation between the period of 1/n and the order of 10 mod n (you're interested in the case gcd(10,n)=1 here, though the other case is worth looking at).
so long as p < 31.
This isn't true, the period of 1/7 is 6, the period of 1/77 is also 6.
infinity? This can't be true either, it will always be finite as 1/pq is a rational number, and hence its decimal either terminates or repeats.
Posted by Shmoe
What is n here? Does n = pq?
Sure, if you like. It doesn't have to be the product of 2 primes though, there's a nice relation between the period of a number n with gcd(10,n)=1 and the order of 10 mod n.
Posted by Shmoe
That got me thinking...
The period of 1/p is the order of 10(mod p) right? so we have a congruence relation:
10^r \equiv 1(\mod p)
The period of 1/q is the order of 10(mod q). So:
10^s \equiv 1(\mod q)
And the period of 1/pq is the order of 10(mod pq). So:
10^t \equiv 1(\mod pq)
No matter what prime p we take, p is always relatively prime to 10 (since p has no divisors anyway). Take a prime. Then suppose that p divides 10^r-1, that is, nm = 10^r - 1 for some integer 1\geq m < 10^r. Then
\frac{1}{n} = \frac{m}{10^r-1} = m(10^{-r} + 10^{-2r} + \dots)
If our integer m = a+0 + 10a_1 + 10^2a_2 + \dots 10^{r-2}a_{r-2} + 10^{r-1}a_{r-1} for decimal digits a_0,\dots,a_{r-1}, then the decimal expansion of 1/p will be
\frac{1}{p} = 0.a_{r-1}a_{r-2}\dots a_1a_0a_{d-1}a_{d-2}\dots a_1a_0\dots
which will repeat with a period that will always divide r.
Then the period of 1/p is the smallest r such that p divides 10^r-1. In other words, the period of 1/p is the smallest d such that
But this is the definition of \mbox{ord}_p(10).
So the period of 1/p is the order of 10(mod p).
Which should mean that
\mbox{per}\left(\frac{1}{pq}\right) = \mbox{ord}_{p+q}(10)
Should be the order of 10 mod pq, not p+q. Now do you know how to find the oder of 10 mod pq from the orders mod p and mod q?
Posted by Shmoe
Of course, pq, nor p+q, I don't know why I wrote that. :confused:
I think I may know, although I kind of jumped at that conclusion without properly running through it.
\mbox{per}(1/p)\times\mbox{per}(1/q)
is the order of 10(mod pq). If you let n = pq (although I may now understand what you mean by this, n can be any integer so long as it is relatively prime to 10?) then
\mbox{per}(1/p)\times\mbox{per}(1/q) = \mbox{per}(1/n)
which is equal to the order of 10(mod n) = 10(mod pq). Which is the same thing as
\mbox{per}(1/pq) = \mbox{ord}_{pq}(10)
Yes. If it's not relatively prime, then it's a terminating decimal.
Remember th 1/7 and 1/11 example? The period of 1/11 was 2, the period of 1/7 was 6, the period of 1/77 was 6, so it's not the product of the periods.
Try a few more examples to see if you can spot a relationship. You might want to think in terms of the order of 10 mod p and q here. Specifically if r is the order of 10 mod p and 10^t=1 mod p then r divides t. Also, if 10^t=1 mod pq then 10^t=1 mod p.
For example
1/7. Find \mbox{ord}_7(10)
10^2 \equiv 2(7)
10^3 \equiv 6(7)
10^4 \equiv 4(7)
10^5 \equiv 5(7)
10^6 \equiv 1(7)
and we have exhausted mod 7. So infact,
\mbox{ord}_7(10) = 6
p=17. Find \mbox{ord}_17(10).
10^2 \equiv 15(17)
10^4 = 15^2 \equiv (-2)^2 \equiv 4(17)
10^8 = 4^2 \equiv 16(17)
Thus we can see that \mbox{ord}_{17}(10) is not 1,2,4, or 8. But we must remember that \mbox{ord}_{17}(10) divides \phi(17) = 16. The divisors of 16 are 1,2,4,8, and 16. Therefore \mbox{ord}_{17}(10) = 16.
Now find \mbox{ord}_{7\cdot 17}(10)
\mbox{ord}_{7\cdot 17}(10) \Rightarrow 10^{rs} \equiv 1(7\cdot 17)
But is there a quicker way of doing this other than working them all out?
Suppose the order of 10 mod 7*17 is t. Then 10^t=1 mod 7*17. So we have both:
10^t=1 mod 7
10^t=1 mod 17
What does this tell you about t compared to 6 and 16 (the orders of 10 mod 7 and 17).
But surely t can't take on two values at the same time?
So 7 divides t-1 and 17 divides t-1. So 6 divides t and 16 divides t. So t=48 works but t=48 = lcm(6,16).
Nope. You maybe mistyped?
Which shows lcm(6,16) divides t. You should also be able to show t divides lcm(6,16), then you'd have equality. Of course showing 10^48=1 mod 7*17 directly would work as well, but you can prove this lcm relation in general.
Yeah, I meant to write
7 divides 10^t - 1 and 17 divides 10^t -1
6 divides 10^t and 16 divides 10^t
which just comes from the definition of
10^t \equiv 1(\mod 7)
and
10^t \equiv 1(\mod 17)
Which makes it that
\mbox{lcm}(6,16) \mbox{ divides } 10^t
7 divides 10^t - 1 implies 6 divides t, not 10^t (as 6 is the order of 10 mod 7). Similiar for 16, which is why we have lcm(6,16) divides t.
Ahah! of course! of course! (I was lucky getting the right answer from incorrect calculations).
So finally we have that if
\mbox{ord}_{pq}(10) = t
then
t = \mbox{lcm}(p-1,q-1)
and since
\mbox{ord}_{pq}(10) = \mbox{per}(1/pq)
we have
\mbox{per}(1/pq) = \mbox{lcm}(p-1,q-1)
What about
\mbox{per}\left(\frac{1}{p^2}\right)?
we have
10^t = 1(mod p^2)
p^2 - 1 divides t
where t = \mbox{ord}_{p^2}(10)
This was luck again! It works for the p=7 and q=17 case, but what if p=7 and q=11?
What!? How can it work for my random choice of prime numbers but not for another choice? Noooo!
Maybe not all is lost...
7 and 17 where peculiar because the period of 1/7 was 7-1, and the period of 1/17 was 17-1. So Ill take a stab in the dark an proclaim:
\mbox{per}(1/pq) = \mbox{lcm}(\mbox{per}(1/p),\mbox{per}(1/q))
Ding, ding, ding! We have a winner (note here the assumption that gcd(p,q)=1). The order of 10 being the lcm of the other orders is the easiest way to think about this, and the easiest way to prove it.
Yay!
I also came up with something for the period of 1/p^2.
Let \mbox{ord}_{p^2}(10) = t
Then
10^t \equiv 1(\mod p^2)
p^2\,|\,t-1
p^2-1\,|\,t
Then p^2-1 divides t. But p^2-1 is always an even number for all primes p. So t is even, since t=\lambda(p^2-1) for some lambda.
But then the period 1/3*1/3 = 1/9 = 0.11111 has a period of 1 which is not even. Argh.
The group of units mod p^2 has order phi(p^2)=p*(p-1). The order of 10 mod p^2 will divide this. Remember Euler's theorem?
When I was working through the proof of the first one with you, it worked because when we did
10^t = 1(mod 7) => 7 | 10^t - 1 => (7-1) | t
and luckily (7-1) happened to be the period of 1/7.
But say we had 11...then
10^t = 1(mod 11) => 11 | 10^t - 1 => (11-1) | t
and now (11-1) is NOT the period of 11.
So if I had been working with say 3 and 11, I would not have discovered the lcm bit! This is why I can't work out the period of 1/p^2.
So when I got to the step
10^t \equiv 1(\mod p)
10^t \equiv 1(\mod q)
p\,|\,t-1
q\,|\,t-1
but now I can't simply say
p-1 | t => per(1/p) | t
because p-1 is the period of 1/p (like I did when p=7,q=11), because p-1 is NOT the period of arbitrary primes. So wha
  • #31
p\,|\,t-1
q\,|\,t-1
You've typed this sort of implication enough times I'm getting concerned it's not a typo. 10^t=1 mod p does not in anyway mean p divides t-1. You do however know that the order of 10 mod p will divide t if 10^t=1 mod p. In other words, if you raise 10 to an exponent and get 1, then this exponent is a multiple of the order. You also know the order of 10 mod p will divide p-1, the order of the group of units mod p is just p-1 (in general it's phi(n)).
  • #32
Excellent. So I was lucky that the period of 1/7 equalled 7-1 AND phi(7) = 7-1. That was where I was getting confused.
So for 1/pq we could have written
per(1/pq) = lcm(phi(p),phi(q))
  • #33
This isn't correct- it's the 'luck' mistake that you just mentioned. You don't necessarily have per(1/p) equal to phi(p). You know per(1/p) divides phi(p) since per(1/p) equals the order of 10 mod p, but that's all you can say.
  • #34
So to answer the question which was "what can we say about the period pf 1/pq?" is exactly that, we can only "say". There is no exact formula for it.
We can say the period of 1/p divides phi(p) and the period of 1/q divides phi(q) because the period of 1/p is the order of 10 mod p (and for q), like you just said. So we can say that the period of 1/pq is a divisor of phi(pq).
  • #35
Yes, but you can also say something about per(1/pq) in terms of per(1/p) and per(1/q), namely per(1/pq) = lcm(per(1/p),per(1/q))
  • #36
And with per(1/p^2) we can say that it too is a divisor of phi(p^2). Which, as you have already said, means that per(1/p^2) divides p*(p-1)
  • #37
Posted by Shmoe
I thought we came to the conclusion that this wasnt true. It was because per(1/7) happened to equal phi(7), and per(1/17) happened to equal phi(17). Now you are saying that it was correct.
  • #38
lcm(phi(p),phi(q)) and lcm(per(1/p),per(1/q)) are not always the same. Look back to posts 25/26.
  • #39
SUMMARY:
1. The period of 1/pq equals the order of 10 mod pq.
2. Let t=ord_(pq)(10).
3. By definition of order, we must have 10^t=1(mod pq).
4. This implies two linear congruences
a) 10^t = 1(mod p)
b) 10^t = 1(mod q)
5. We know that t divides ord_p(10) <=> 10^t=1(mod p)
6. We know that t divides ord_q(10) <=> 10^t=1(mod q)
7. We also know that ord_p(10) divides p-1 (or in other words phi(p)).
8. From 4a and 4b we know that if t divides two different numbers then it must divide their lowest common multiple. That is, t must divide lcm(ord_p(10),ord_q(10)).
9. Which means that t divides lcm(phi(p),phi(q)).
How does this look?
  • #40
It doesn't look right at all. t divides ord_p(10) does not mean that t divides phi(p). ...(or does it?)
  • #41
These are backwards.
ord_p(10) divides t<=> 10^t=1(mod p)
This is true, but not necessary. You have a phi fixation.
This is backwards. You'll have ord_p(10) and ord_q(10) dividing t, and hence so does their least common multiple.
In the direction you are trying to go, you need something like (4)=>(3), which follows when p and q are distinct primes (hence relatively prime). This will let you show the order of 10 mod pq divides the order of of 10 mod p and 10 mod q, so it divides their least common multiple.
Again true, but saying t divides lcm(per(1/p),per(1/q)) is in general stronger.
  • #42
Thankyou Shmoe for all your help and patience. I believe I can now write a correct solution.
  • #43
**bump**
I'm working on a similar problem, ie, I need to find the period of 1/pq if (p,q) = (p,10) = (q,10) = 1.
If the period of 1/p is r and the period of 1/q is s, then
10^r \equiv 1 (p) \mbox{ and } 10^s \equiv 1 (q).
So, let t be the period of 1/pq, ie, 10^t \equiv 1 (pq), then 10^t \equiv 1 (p) \mbox{ and } 10^t \equiv 1 (q).
Now r|t and s|t (since if the order of a mod n is k and a^t \equiv 1 (n), then k|t). This implies that \textstyle \left. \frac{rs}{\mbox{gcd}(r,s)} \right| t \Rightarrow \mbox{lcm}(r,s)|t.
I just have to show that t|\mbox{lcm}(r,s) so I can say the period of 1/pq is exactly \mbox{lcm}(r,s) and I'm done (I think). I'm a bit stuck with this last bit though. Am I on the right track here or is there some other obvious way of going about this?
Thanks for any help.
