Red Shift and Receding Galaxies
Redshift is a key indicator of the universe's expansion, as it shows that galaxies are moving away from us. Astronomers measure redshift by comparing the absorption lines of elements like hydrogen in galaxy spectra to those produced in laboratory conditions, finding that the galaxy lines appear at longer wavelengths. The speed at which galaxies recede increases with distance, supporting the idea of an expanding universe, akin to points on an expanding cookie sheet moving apart. This phenomenon is attributed to the stretching of light waves due to the expansion of space, rather than the Doppler effect. Understanding these concepts is essential for grasping the evidence behind an expanding universe.
Peter G.
Hi,
I understand the idea of red shift and how that explains that galaxies are receding, etc.
I just don't understand how the measurement is made.
I know that, in labs, we can shine white light at hydrogen and analyze the absorption spectrum. Some black lines are going to show up, due to the fact that specific wavelength corresponds to a frequency, which corresponds to an energy that is equal to one of the change in energy levels of that element.
But what do they measure/analyze in order to get the red shifted spectrum? I am terribly confused! :redface:
Thanks!
Astronomers look for the same absorption lines of hydrogen and other elements in the spectra of galaxies as the absorption lines produced by these elements in the lab. They find that the absorption lines for the galaxies occur at longer wavelengths than those in the lab.
You can find lots of info by just doing a web search on "redshift galaxies". For example,
http://astro.wku.edu/astr106/Hubble_intro.html
I see! Thank you.
Oh and, if you don't mind, could you help me with another problem I am having?
I understand how the red shift of light from distant galaxies can be used as evidence for an expanding universe. But, how does the fact that the galaxies further away are moving faster serve as evidence too?
The redshift of galaxies is due to the expansion of space itself. A galaxy farther away will increase its distance from us faster than a nearby galaxy because there is more space between us and the distant galaxy to expand. An analogy would be to put a cookie sheet in an hot oven. The sheet will expand while its temperature is increasing. The speed at which two points of the sheet move away from one another while the sheet is expanding is proportional to the distance separating them.
However, analogies can be misleading. The redshift of light from galaxies is not due to the doppler effect. Rather, the wavelength of light from distant galaxies is stretched by the expansion of space itself. At least that's my understanding.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
