Redshift of Far Galaxies: What Causes It?
The redshift observed in light from distant galaxies is primarily attributed to the expansion of the universe, which stretches the light waves as they travel through space. This phenomenon means that light emitted from galaxies further away appears redder because it has taken longer to reach us, effectively showing us a snapshot of the universe's past. Although it might seem that two events occurring simultaneously would yield the same redshift, the distances involved mean we are observing light emitted at different times. The relationship between distance and redshift was first noted by Hubble and aligns with principles in General Relativity. Understanding redshift involves recognizing that the universe's expansion complicates the straightforward interpretation of distance and time.
JD88
Hi,
I have a question about the redshift caused by the expanding universe. I am not a physicist and reading books and articles about physics is just a hobby so I apology if this is obvious to most of you.
I have read somewhere that the light from far away galaxies is redder than light from nearer galaxies. Why is this?
I understand that the redshift is caused by the expanding universe stretching the light but wouldn't the amount of redshift only depend on how long ago the light was emitted? I would have thought that two event happening at the same time would have the same redshift because the universe has expanded by the same amount for both events.
Space news on Phys.org
You are correct, in general. Note that galaxies that are further away emitted their light longer ago. If we see things from the same time, then we see them at the same distance... apart from local motions over the general Hubble flow.
Some folks here don't like describing the cause of redshift as stretching from expanding space, and they have a point. But it works in the sense of giving you the right answers, and a lot of the simple explanations in cosmology can depend on how you choose to look at it. The underlying maths is the same.
Cheers -- sylas
The farther away something is, the older it appears. Looking, for example, 1 billion light years away is like looking 1 billion years in the past, because the light took 1 billion years to reach you.
So yes, if you were looking at two objects that emitted their light at the same time, then the redshift would be the same. The fact that they are different distances away means that we are looking at light emitted at different times.
Hope it helps :).
Nobody knows the answer to that. It is simply a relationship that Hubble noticed when measuring the distances to about 50 galaxies. However, it turns out to be consistent with a simple concept in General Relativity, namely expansion.
JD88 said:
I understand that the redshift is caused by the expanding universe stretching the light ...
That is indeed the mainstream interpretation.
What is wrong with that?
Not exactly. If space is expanding, then the concept of distance itself is not this straightforward. For instance, something that is 1 billion lyrs away now will be even further away by the time light arrives from it (assuming an open universe). Inversely, light that has traveled 1 billion years from its source has traveled from a source that was actually closer than 1 billion lyrs when it was emitted, and is now actually much further away (assuming that expansion can be extrapolated 1 billion years into the past).
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
