Reduction of Order no independent or dependent variable
The discussion revolves around a second-order differential equation of the form y'' + (y')^2 = 6(y') - 9. Participants are exploring methods to reduce the order of the equation and manipulate it into a solvable form.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants attempt to transform the original equation by substituting u = y' and rewriting the equation in terms of u. There are discussions on integrating the resulting expressions and addressing the constant of integration. Some participants express confusion about separating variables and the correct manipulation of terms.
There is an ongoing exploration of different approaches to the problem. Some participants have provided guidance on correcting earlier mistakes, such as addressing typos and the omission of constants. Multiple interpretations of the steps involved are being discussed, with no clear consensus yet on the best path forward.
Participants note the challenge of the problem, with some expressing frustration over the time spent on it. There is an acknowledgment that others in class may have found a more straightforward solution.
gremmie
y'' +(y')^2 = 6(y') -9
u = y'
u' = y''
equation from 1 becomes
u' + U^2 = 6u - 9
du/dx + u ^2 = 6u-9
du/dx = -u^2 + 6u -9
du/dx = -(u^2 +6u - 9)
du/dx = -(u-3)^2
du/(u-3)^2 = - dx
integrate both sides
1/(u-3) = x
sub in dy/dx
1/(dy/dx -3) = x
from this point I've tried multiple ways to get dy and dx separated but I am not doing something right... thanks for the help
u = y'
u' = y''
u' + U^2 = 6u - 9
du/dx + u ^2 = 6u-9
Typo above. It should be -(u^2 - 6u + 9)
gremmie said:
du/dx = -(u-3)^2
du/(u-3)^2 = - dx
1/(u-3) = x
You're missing the constant of integration. Also, instead of substituting dy/dx as you're doing in the next step, solve for u, then substitute.
gremmie said:
sub in dy/dx
1/(dy/dx -3) = x
Ah yep sure did have a typo ...thanks ...sorry first time posting...yep i left my constant of integration off as well..
Ok so picking up where i left off but this time solving for u
1/(u-3) = x +C
1 = (u-3)(x+C)
ux+uc = 1 + 3C +3x
u(x+C) = 1+3C +3x
u = (1+3C +3x)/(x+C)
sub for u
dy/dx = (1+3C +3x)/(x+C)
dy = (1+3C +3x)/(x+C) dx
u sub u = x+c
du = dx
Integral (3u+1)/u
s sub
s = 3u+1
ds = 3du
integral s/(s-1)
integral 1 + 1/(s-1)
integral 1 +integral 1/(s-1)
p sub for 1/(s-1)
thus integral dp/p
evaluate integrals
s +lnp + C2(2nd constant of integration)
sub back
s + ln(s-1) +C2
3u + 1 +ln(3u+1-1) +C2
3u + 1 +ln(3u) +C2
3(x+C) +1 +ln(3x +3C) +C2
so
y= 3x + 3C +1 +ln(3x+ 3C) +C2
the answer listed is : y = 3x +ln(x+C) +C2
So i see that I am on the right track ... but I am still missing something again .. thanks
1/(u-3) = x +C
1 = (u-3)(x+C)
ux+uc = 1 + 3C +3x
u(x+C) = 1+3C +3x
You sure took the long way around. Starting from your first equation,
1/(u-3) = x +C
==> u - 3 = 1/(x + C)
==> u = 3 + 1/(x + C)
Undoing the substitution,
dy/dx = 3 + 1/(x + C)
==> dy = [3 + 1/(x + C)]dx
==> y = 3x + ln|x + C| + D
sub for u
u sub u = x+c
du = dx
Integral (3u+1)/u
s sub
s = 3u+1
ds = 3du
integral s/(s-1)
p sub for 1/(s-1)
thus integral dp/p
evaluate integrals
sub back
s + ln(s-1) +C2
3u + 1 +ln(3u) +C2
so
[/quote]
ah man i sure did... Well thanks for your help! I knew there had to be an easier way! everyone in class got this problem done in class an I've been messing with it for about 2 weeks! Again, Thank You.
  • · Replies 18 ·
