Solving Refraction Problem: Aim Flashlight at What Angle?
  • Thread starter Thread starter roxxyroxx
    Refraction
To determine the angle at which to aim a flashlight to illuminate a penny at the bottom of a pool, the index of refraction for water (1.33) is essential. Using Snell's Law, the calculations initially led to incorrect angles, with attempts yielding results of 22 degrees and 37 degrees. The correct approach involves calculating the angle of incidence with respect to the normal and then converting it to the angle relative to the pool deck. The final required angle to aim the flashlight is found to be 54 degrees. Understanding the relationship between angles and refraction is crucial for solving this problem accurately.
roxxyroxx
A penny lies on the bottom of a pool 0.75m from the edge of the pool and 1.5m below the surface. A flashlight beam is shone over the edge of the pool to illuminate the penny. At what angle to the pool deck should the flashlight be aimed?
You're going to need the index of refraction aren't you?
Water is 1.33. Is that what you are supposed to use?
If you don't know it already, then maybe better look at Snell's Law.
Hi roxxyroxx! :wink:
(I assume it means that the light enters the pool exactly at the edge?)
Use the sin/sin rule …
show us how far you get, and where you're stuck, and then we'll know how to help! :smile:
ok well i did sin(0.75/1.5) --> sin^-1(0.75/1.5) giving me 30 degrees so:
(1.00)(sin 30) = (1.33)(sin theta)
sin theta = 0.3759...
theta = 22 degrees
but the answer should be 54 degrees
theta = 22 degrees
Isn't the angle you want from entering the water given by
tan-1(.75/1.5) = θ
ok so tan^-1(0.75/1.5) = 26.565...
(1.33)(sin 26.565...) = (1.00)(sin theta)
sin theta = 0.595
theta = 37 degrees
but the answer is 54 ..
sin theta = 0.595
theta = 37 degrees
This angle is the angle which the light makes with the normal to the pool. But the answer required is the angle to the pool deck.
So the required angle is 90 - theta
ookk thank you! >.<
  • · Replies 18 ·
17K
