brainstorm said:
Thanks for your responses, Doc Al and Jesse M. I see that you both calculated 0.92C regarding the acceleration of the vessel from 0.9C another 0.11C. Now, can you take this back to the concrete level of the scenario I posted. Recall that the distant galaxy was expanding away from Earth at 0.9C, so by the time the ship arrived at Earth doing 0.9C relative to the point of departure, it was standing still relative to Earth.
How could it "arrive at Earth" if it was at rest relative to the Earth as soon as it departed the distant galaxy? If it was at rest relative to the Earth when it was still in the neighborhood of the galaxy, then the distance between it and the Earth never would have shrunk.
Also, if you want to discuss a problem in the context of special relativity, you can't assume space is expanding, since that only happens in general relativity where spacetime can be curved. It's much easier if we assume the laws of special relativity apply and the distant galaxy just happens to have a speed of 0.9c relative to the Earth in uncurved spacetime, rather than assuming space is actually expanding between them--is that OK for the purpose of discussion? In studying relativity it's best to
"learn to walk before you run", to get some idea of the basics of special relativity before you try to understand how things work in general relativity.
brainstorm said:
Let's just assume it takes a break and actually goes into orbit around Earth. At that point it behaves the same as anything else in orbit around Earth, right? Ok, now it decides to accelerate in its original direction from Earth to a velocity of, say, 0.5C.
Remember, velocities can only be stated relative to a particular frame of reference. Do you mean that the ship is traveling at 0.5c in the rest frame of the Earth?
brainstorm said:
When someone inside looks back at its original point of departure, does it see anything at all since it is going 0.5C relative to Earth and Earth was expanding away from its original galaxy at 0.9C?
In the Earth's frame if the ship is moving at 0.5c, then any light signal from the distant galaxy will be traveling at 1c, so no matter how far away the galaxy is when it emits a given signal, the signal will eventually be able to catch up with the ship (again I am assuming we are dealing with ordinary flat spacetime rather than expanding space, since expanding space can mean that certain light signals will never reach certain objects). Meanwhile in the galaxy's frame, the ship is only traveling at (0.9c + 0.5c)/(1 + 0.5*0.9) = 1.4c/1.45 = 0.9655c, so it also makes sense that any signal from the galaxy will eventually catch up with the ship when we analyze things from the perspective of this frame.
brainstorm said:
Sorry for all the confusion, but I don't see how accelerating from Earth to 0.11C when Earth is moving away from the galaxy at 0.9C results in a total velocity of 0.92C.
Did you read my point about how each frame defines "speed" in terms of distance/time as measured by rulers and clocks at rest in that frame, and rulers at rest in one frame will be shrunk in other frames, while synchronized clocks at rest in one frame will be running slow and out-of-sync in other frames? For a numerical example, you might take a look at
this post where I showed how two observers using their own clocks will each measure the speed of the same light beam as 1c, because of the way rulers shrink and clocks become time-dilated and out-of-sync when viewed in a frame where they're in motion (so in spite of the fact that one observer measures the light beam to move at 1c relative to himself, and the fact that the second observer measures the first to move at 0.6c relative to himself, that doesn't imply that the second observer measures the light beam to be moving at 1.6c relative to himself)
