Regenerative Braking: Efficiency & EVs - An Overview
  • Thread starter Thread starter robinfisichel
The discussion revolves around regenerative braking systems in electric vehicles (EVs), focusing on their efficiency, energy recovery, and the technical challenges associated with their implementation. Participants explore theoretical aspects, practical applications, and hypothetical scenarios related to regenerative braking.
  • Some participants mention that regenerative braking systems can recover around 31% of a vehicle's kinetic energy, but the actual efficiency may vary.
  • There is a discussion about the use of supercapacitors to store energy during braking, with questions raised about why batteries need to be recharged if energy can be used directly from the capacitors.
  • Concerns are expressed regarding the need to limit the maximum charge of batteries during regenerative braking to prevent overcharging, and the potential role of capacitors in this process.
  • One participant notes the practical difficulties of implementing a kinetic energy recovery system (KERS) in real life compared to theoretical exercises, emphasizing the complexity of control systems.
  • Another participant discusses the limitations of existing drive cycles for EVs, which may not accurately reflect braking decelerations, thus affecting energy recovery calculations.
  • A hypothetical example is provided to illustrate energy recovery calculations, including specific figures for energy change, efficiency, and power output during braking, leading to a discussion on the feasibility of recovery rates.
Participants express a range of views on the efficiency and practicality of regenerative braking systems, with no clear consensus on the optimal approach or the effectiveness of current methods. Multiple competing perspectives on the use of supercapacitors and battery management are present.
Participants acknowledge that the efficiency of regenerative braking can depend on various factors, including the specific vehicle design, braking routines, and the characteristics of the energy storage systems used. There are also unresolved questions regarding the management of energy flow between batteries and capacitors.
This discussion may be of interest to engineers, researchers, and students involved in electric vehicle technology, energy systems, and control systems, as well as those exploring the practical applications of regenerative braking.
robinfisichel
Another EV related question from me, I would like to know a few things about regen braking...
1. For typical cars, how efficent are regen systems, I've seen 31% quoted http://engineering.wikia.com/wiki/Regenerative_braking as in how much of the kinetic energy of a vehicle is recoverable
2. Since batteries can't allways take the high amp current transfer in the time it takes to brake some EV's use supercapacitors to store the energy and then recharge the batteries slowly, but why recharge the batteries if you can just use the energy straight from the capacitor.
3. If i am recharging the battery using regen does this mean i have to somehow limit the maximum charge of a battery to prevent current being pumped into a full battery?? Cant i just send it to a capacitor? But what happens if the capacitor is full, where can i send the charge?
I was going to mention this in the other thread, that charging and discharging batteries using a kers type system isn't as easy as people made out.
It's easy if its a paper exercise. (ie this is a Uni style project). But making one acutally work in real life is a whole different game, and ususally a much bigger PITA.
Supercapaciters are used as they can be charged very quickly and don't require charge monitoring (once they reach capacitance they simply won't charge any more). However they 'leak' charge, so over time they will lose their charge even if not used. Another factor as to they they aren't used is that they only deliver full voltage when fully charged. So for example a battery can deliver a steady voltage, the capitor won't.
So you can dump power into them and use them to trickle recharge a battery until it reaches a set amount (they usually keep betteries charged 50%-95% (I pulled this figure from memory so it may be rubbish) but they don't tend to fully charge something, just incase of a surge (the 5% gives a little leeway for problems). Control systems are key to this sort of thing, and that's all way beyond me.
Cool, nice info, i think that's what i hear as wel. Control systems are way beyond me as well! My design is really hypothetical so I am not worrying about this too much.
One problem with the drive cycle i used for the EV is its aimed at emmissions testing (as are most) so doesn't incorporate proper braking decelerations and therefore i recover barely anything.
I will have to make my own braking routine to see what kind of values for energy recovery.
I want to do a quick example of this, just to see how worthwile regen breaking would be.
If the car brakes from 40-0mph in 4 seconds (about 0.4g) the change in energy is 95925 J for a 600kg car. Assuming 31% efficiency this makes available 29736 J.
In terms of power this is producing 7.4kW and stores 8.2 Wh of energy.
Assuming i divide by the nom voltage of the battery pack (not sure about this) then that's 47 Amps which would be too great for charging some liion batteries i think.
In one of my cycles i break 14 times per cycle, and the cycle is repeated 16 times, the total power used is 15000 kWh. So the energy recovery would be 8.2 x 14 x 16 = 1905.68 Wh which is 12.7% recovery. Which i guess is ok, i was told the system doesn't add much weight, though the cost would be higher for the controller units...
  • · Replies 35 ·
  • · Replies 21 ·
10K
  • · Replies 27 ·
12K
