How Does Regge Calculus Define a Minimum Quantum of Spacetime?
  • Thread starter Klaus_Hoffmann
In summary, the conversation discusses the problem of defining a minimum quantum of spacetime, particularly in relation to the Regge Calculus. The concept of discreteness in Regge approach and other quantum gravity theories is also mentioned, with a clarification that quantization does not necessarily mean atomization of space and time.
Klaus_Hoffmann
86
Let be a (3+1) spacetime so we use triangularization of it computing 'Riemann Tensor' and so on, the problem is How can we define a 'minimum' Quantum of Space time (Area and Volume of the Surface should be quantizied) involivng the Regge Calculus ??
Klaus as far as I know area and volume are not in any sense discrete in Regge approach.
that is not unusual in non-string QG
for example in CDT approach you let the size of the simplexes go to zero.
also in the Spinfoam approach there is AFAIK no smallest distance or area or volume----no discreteness.
however in canonical LQG there IS a discreteness result---the theory is not based on a discrete space, it is based on a continuum, but you can PROVE (in this one particular approach) that the area and volume operators have discrete spectrum. this should not be taken to mean that space is "made" of "atoms of space", it just means that certain observables representing the result of certain measurements have a discrete spectrum of possible outcomes.
quantization does not mean atomization. A quantum theory of spacetime geometry does not mean that there are atoms of space or time. There can be that in some approaches and NOT be that way in other approaches.
The combination of Regge Calculus and Quantization is a promising approach to understanding the fundamental structure of spacetime. By using the triangulation method, we can discretize the continuous spacetime into small triangles, allowing us to compute the Riemann tensor and other geometric quantities. This can provide valuable insights into the curvature and dynamics of spacetime.
One of the key challenges in understanding the quantum nature of spacetime is defining a minimum unit of space and time. This is where the Regge Calculus can play a crucial role. By quantizing the area and volume of the triangulated spacetime, we can define a minimum quantum of space and time. This would allow us to probe the structure of spacetime at a more fundamental level and potentially uncover new physics.
However, there are still several open questions and challenges in this approach. For instance, how do we ensure that the quantization of space and time is consistent with the principles of quantum mechanics? Can we extend this approach to higher dimensions? These are important questions that need to be addressed in order to fully utilize the potential of Regge Calculus and Quantization in understanding the nature of spacetime.
Nevertheless, the combination of these two powerful techniques holds great promise in shedding light on the fundamental properties of spacetime and its connection to quantum mechanics. It is an exciting area of research that has the potential to revolutionize our understanding of the universe.
What is Regge Calculus?
Regge Calculus is a mathematical framework used to describe the geometry of curved spaces. It is based on a discretized version of General Relativity, where the continuous space-time is divided into smaller sections (called simplices) and the curvature is approximated by calculating the deficit angle at each simplex.
What is Quantization?
Quantization is a process used in physics to convert classical systems (described by continuous variables) into quantum systems (described by discrete variables). In the context of Regge Calculus, quantization is used to describe the dynamics of the simplicial geometry at the discrete level.
How is Regge Calculus used in the study of General Relativity?
Regge Calculus is used in the study of General Relativity to approximate the continuous space-time described by Einstein's equations. By discretizing space-time into smaller simplices, it becomes possible to numerically solve for the curvature and study the dynamics of the space-time geometry.
What are the advantages of using Regge Calculus for quantization?
Regge Calculus has several advantages for quantization, including the ability to handle non-perturbative effects and the ability to incorporate topological constraints. It also provides a more intuitive and geometric interpretation of the quantization process.
What are some current applications of Regge Calculus+Quantization?
Regge Calculus+Quantization is currently being used in various fields such as cosmology, black hole physics, and quantum gravity research. It has also been applied to study the dynamics of lattice quantum systems and to model quantum phase transitions.
  • Beyond the Standard Models
