Relap thermodynamic property error
The user is experiencing a thermodynamic property error in relap during a blowdown transient simulation, which occurs with actual heat fluxes and is delayed by reducing the time step. Halving the heat fluxes allows for longer run times but eventually leads to a 'courant limit exceeded' error. Suggestions include increasing flow rates and pressure to align with the heat fluxes and reviewing the code version and user manual for insights on the Courant limit and stability. Additionally, checking the simulation inputs may help resolve the issue. Proper adjustments to these parameters could improve simulation stability and performance.
Vnt666Skr
Hi I am using relap to study a blowdown transient. If I let it run it with actual heat fluxes, the program terminates with error message saying thermodynamic property error with maximum time step. Reducing the time step delays the onset of the error by a fraction of a second.
Runs much longer if I halve the heat fluxes until it fails again, citing 'courant limit exceeded' error
Any ideas?
What flow rates or mass fluxes is one using? Are they appropriate for the heat fluxes and pressure in the correlations? One approach would be to increase the flow rates and possibly the pressure.
What version of the code is one using?
Has one reviewed the theory or user manual for information on the Courant limit and stability?
Perhaps also check the inputs.
Hello everyone, I am currently working on a burnup calculation for a fuel assembly with repeated geometric structures using MCNP6. I have defined two materials (Material 1 and Material 2) which are actually the same material but located in different positions. However, after running the calculation with the BURN card, I am encountering an issue where all burnup information(power fraction(Initial input is 1,but output file is 0), burnup, mass, etc.) for Material 2 is zero, while Material 1...
Hi everyone, I'm a complete beginner with MCNP and trying to learn how to perform burnup calculations. Right now, I'm feeling a bit lost and not sure where to start. I found the OECD-NEA Burnup Credit Calculational Criticality Benchmark (Phase I-B) and was wondering if anyone has worked through this specific benchmark using MCNP6? If so, would you be willing to share your MCNP input file for it? Seeing an actual working example would be incredibly helpful for my learning. I'd be really...
