Related to Constant acceleration
The discussion revolves around calculating the time it takes for a child in a go-cart to travel from the 4m mark to the 40m mark under constant acceleration. The initial velocity is 4m/s, and the acceleration is 0.4m/s², leading to a distance of 36m to cover. The correct approach involves using the equation d = V1*t + (a*t²)/2, which simplifies to a quadratic equation. The final calculation reveals that the time taken is approximately 6.7 seconds, confirming the accuracy of the method. Participants emphasize the importance of using the correct formulas and algebraic manipulation for solving such physics problems.
HelpMeHelpYou
Suppose a child driving a go-cart is traveling 4m/s when she crosses a line 4m from her starting point. She continues with a steady acceleration of 0.4m/s^2 , until she crosses a mark 40m from the starting point. How long does it take for her to go from the 4m mark to the 40m mark?
what i did is this :
a = 0.4m/s^2
Vi = 4m/s
d = 40m - 4m = 36m
i used this formula :
Vf = Vi + a*t
0 = 4m/s + (0.4m/s^2)t
-0.4m/s^2 = 4m/s
t = -10s
and this :
d = Vi+Vt/2 * t
36m = (4m/s + 0)/2 * t
36m = 2m/s t
divide both side by 2m/s
t = 18s
but the true answer is 6.7s
anyone correct this ?
the direct way to solve it, without having to calculate the final velocity, is to use
d = V1 t + a t2 /2
put in the values d= 36, a=0.4 and solve the quadratic equation in t using the normal formula. Its obviously the positive value of t you take.
Hope this helps
Regards
Sam
how about the velocity ? Vi = 0 or 4m/s ?
4 m/s
36=4t+0.2t^2
just a confirmation ..
correct this if I'm wrong ..
d = 36
a = 0.4
i used :
d = V1 t + a t2 /2
subst:
36 = 0 t + 0.4 t2 /2
divide both sides by 0.4
90 = t2 /2
divide both sides by 1/2
45 = t2
square root both sides to remain t :
t = 3√5 or 6.7
is it correct usage of algebra ?
try 36 = 4t+0.2t2
0.2 t2 +4t -36 =0
t = (-4 + √(16+4*0.2*36))/(2*0.2)
t≈6.7 seconds
whow ! again .. i should study back again .. so thanks Sam ..
gratitude !
