Relation between kinetic energy and temperature
The term 3/2 in the equation \(\frac{1}{2} mv^2 = \frac{3}{2} kT\) arises from the three translational degrees of freedom of a particle, each contributing \(\frac{1}{2} kT\) to the total kinetic energy. This relationship is explained by the equipartition theorem, which states that energy is equally distributed among all degrees of freedom. The derivation involves equating two ideal gas equations: one derived experimentally (PV=RT) and the other from kinetic theory (PV=Nmc²/3). The Hyperphysics site is recommended for further exploration of these concepts. Understanding this relationship is crucial for grasping the fundamentals of kinetic theory and thermodynamics.
johnathon
Where does the 3/2 come from?
Science news on Phys.org
A particle can move in any of three directions (that's where the 3 comes from), with kt/2 being the kinetic energy carried by motion on each the x,y or z dimensions.
This link gives a short and sweet bit of book work. That Hyperphysics site is good for many things, actually.
There are three translational degrees of freedom, each contributing 1/2kt to the total energy. This from the equipartition theorem.
Taking it back a step the 3kT/2 can be found by equating the two ideal gas equations,one being obtained experimentally(PV=RT) the other being obtained theoretically using kinetic theory(PV=Nmc bar squared/3)
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
