Relation between magnetic and electric fields
The discussion revolves around determining the electric field strength at the position of a proton, given specific values for magnetic field strength and force. The context involves the application of the Lorentz force equation in the realm of electromagnetism.
  • Participants explore the use of the Lorentz force equation, questioning how to incorporate known quantities such as velocity, magnetic field, and force to solve for the electric field. There are discussions about the role of angles in the problem and the vector nature of forces involved.
Some participants have offered guidance on using vector representations and the importance of sketching diagrams to visualize the forces. Others express confusion regarding the direction of the electric force and how to apply the information given in the problem.
There are mentions of specific values and conditions, such as the angle between vectors and the type of particle involved (proton vs. electron), which may influence the approach to solving the problem. Participants also note the need for clarity on the direction of forces based on charge polarity and vector components.
tboyers
What is the electric field strength at the position of the proton in the figure?(Figure 1) Assume that B = 0.10 T and F = 3.4×10−13N .
Figure 1: https://session.masteringphysics.com/problemAsset/1385081/6/35.P29.jpg
Honestly I don't know. Since we have a velocity, b-field, and force i thought F=qvXb but that doesn't help with solving the electric field. Other than that I really don't know.
I really haven't even been able to start. I have no idea how to approach the problem.
Welcome to the PF.
The Relevant Equation is the Lorentz Force. Look that up in your study materials or Google it online, and then start filling in the known quantities to solve for the unknown E field strength and direction. :smile:
Welcome to the PF.
So I use F = qE + qvXB, they give me the v, B, F, and q since it is a proton. Then i just solve for E right? Where would the angle of 30degrees come into play?
Good! The Lorentz Force equation is a vector equation. Are you able to solve it using vectors?
Ah ok, i got it, thank you.
I know this post was 4 years ago, but I'm working on a similar problem, and I can't seem to figure out how to do it with vectors. I have all the numbers needed, but I can't figure out where to use the 30 degrees
Welcome to PhysicsForums. :smile:
Define your x,y,z coordinate system (label the diagram), and write your vector Lorentz force equation. Can you show us that much? And then you just solve that equation -- you have the vector resultant force on the lefthand side (LHS) of the equation, and you have the electric force vector and magnetic force vector terms on the RHS...
For the problem that I'm working on, F=2.4x10^-13 N and B=.17 T, the velocity is the same, and it's an electron. So the equation would be
F=qv x B + qE
I understand that much, but the angle between v and B is 90, so it just goes to qvB because sin(90)=1.
I know qE has to have some vector component attached to it, but I can't figure out what that is. And the force would just be the 2.4 x 10^-13, because if you take the x and y components and find the magnitude it's the same thing, right? So I'm just confused... because I can't get the right answer and I'm on my last attempt.
The net force on the proton (which you are given) is the vector sum of the electric force (whose direction you know) and the magnetic force (whose magnitude and direction you know). Make a good drawing with these three forces and it should become clear how to solve this. There is more than enough info. supplied in the problem.
Sorry I have no idea what this says. There are many correct ways to represent any vector. I think you only need the "vertical"(or y) components to get your answer, but your problem statement is a bit sketchy.
I'm sorry I guess I'm really dumb, but how do I know the direction of the electric force? I'm given the net force and because I'm given v and B, I can figure out the direction of the magnetic force (right hand rule), but I guess the direction of the electric force might be where I'm lost? As many times as I read your responses I can't figure out what I'm missing! I do not have a physics brain and vectors in these contexts have always confused me a lot. I appreciate all the help!
From the direction of the Electric field and the polarity of the charge, ##\vec{F} = q\vec{E}##
BTW, it helps in posting if you learn to use LaTeX math symbols (it's pretty easy to learn). See the LaTeX Guide link at the lower left of the Edit window. You can also "Reply" to my post above to see the in-line LaTeX that I used to post that equation. :smile:
It's always good to start with a diagram.
Start with a sketch of the vectors of the known net force and the known (with your knowledge of the Lorentz force) magnetic force on the particle. Can you show this?
Then you'll need to find a force vector that when summed with the magnetic force vector results in the net force vector. That force is supplied by the electric field.
I've done the sketch myself, and to me it looks like you'll need to counteract a bit of Y-direction force and supplement a bit of negative X-direction force... Once you have those E-field force components you should be able to sketch in the E-field force vector. With that you should be able to find the field magnitude and direction.
I figured it out thank you!
  • · Replies 16 ·
