Relations between the sides of a triangle, and everythign is underroot
  • Thread starter Thread starter dharavsolanki
    Relations Triangle
dharavsolanki
The relation to be proved looks pretty simple. However, there is no evident point from whih I can start.
How do I start relating quantities that are under root? The cyclic order of the sides on the left side is reminiscent of the cosine rule, but that's just it!
Plus the right hand side has the sum of three surds. I don't see a drect arrival at such an expression. So, where do we start from?
Is there a relation to be picked up which can then be manipulated to reach both the sides? Or some geomterical constraint that we need to be thinking about?
Mathematics news on Phys.org
To prove:
root a + b -c + root b + c -a + root c +a - b is less than equal to root a + root b + root c
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
19K
