Relations on the Kinetic velocities in a cyclic reaction
In summary: This is not always true. At equilibrium, v1 = v2 = v3 = 0. This does not mean that no reactions are occurring; they are, but all at the same rate, so that there is no net change in any of the concentrations.
Ssnow
182
Hi to all, I whant to ask a question about theoretical chemistry. Let us consider a cyclic reaction ##\alpha A\rightarrow \beta B\rightarrow \gamma C\rightarrow \alpha A## where ##\alpha,\beta;\gamma## are the stochiometric coefficients and ##A,B,C## chemical molecules ... there are relations between the three Kinetic velocities ##v_{1}=k_{1}[A]^{\alpha}##, ## v_{2}=k_{2}\left[B\right]^{\beta}##, ##v_{3}=k_{3}[C]^{\gamma}## ?
Ssnow
Chemistry news on Phys.org
Could this be a homework question? Just in case it is, I am only going to give you guidelines, and not the answer.
I am unsure what you are trying to ask because of the poor grammar, but are you asking what rate equations can be derived based on the chemical equation ##\alpha A\rightarrow \beta B\rightarrow \gamma C\rightarrow \alpha A## ?
Of course there are relations between the kinetic velocities because the end product is the initial reactant. Think about how [A] evolves. Obviously, you have the first equation that shows kinetic velocity of reaction from [A], which shows that [A] decreases in the rate ##k_{1}##. But at the same time, it should increase due to the reaction from [C], right? So what modification do you need for the first equation ##v_{1}=\frac{d[A]}{dt}=k_{1}[A]^{\alpha }##?
Sorry HAYAO, my mistake " I *want to ask ... "
In fact was only a curiosity, it is not a homework question, I thought (from an algebraic point of view) to this relation on velocities: ## v_{1}+v_{2}+v_{3}=0##,
this statement has sense ?
Thanks,
Ssnow
PS. I am not an expert in the field...
Hmm.
Well, let's see, the equations are actually,
$$v_{1}=\frac{d[A]}{dt}=k_{1}[A]^{\alpha }-k_{3}[C]^{\gamma }$$
$$v_{2}=\frac{d[B ]}{dt}=k_{2}[B ]^{\beta }-k_{1}[A]^{\alpha }$$
$$v_{3}=\frac{d[C]}{dt}=k_{3}[C]^{\gamma }-k_{2}[B ]^{\beta }$$
So yes, you are right.
$$v_{1}+v_{2}+v_{3}=0$$
Likes Ssnow
Ssnow said:
v1+v2+v3=0
This will not be true generally. At equilibrium, if the system comes to equilibrium, v1 = v2 = v3 = 0. This does not mean that no reactions are occurring; they are, but all at the same rate, so that there is no net change in any of the concentrations.
You have to be a bit careful. In reaction 1, α As react to give β Bs, while in reaction 3, γ Cs react to give α As. So
d[A]/dt = - αk1[A]α + αk3[C]γ
Moreover, I take OP to mean that v1 is the rate of reaction 1, etc. so v1 ≠ d[A]/dt.
What you get is
1/α*d[A]/dt + 1/β*d[B ]/dt + 1/γ*d[C]/dt = 0
If v1 is defined as k1[A]α, etc., then all the v's are positive (none of the reactions is shown as reversible) and their sum must be positive (except when it is zero at equilibrium).
Likes Ssnow
1) Ok this was my dubt, in fact ##v_{1},v_{2},v_{3}## are as @HAYAO wrote before and not how I supposed in my question ...
2) My situation is not an equilibrium situation
3)Thank you @mjc123 for detail and clarifications ...
Ssnow
I totally forgot about the order of reaction. Sloppy mistake. Thanks.
Hmm. That's a good point. I was not entirely sure how OP defined the rate of reaction.
Whether it is an equilibrium or not depends on the initial condition and how much time has elapsed. If your situation is not at equilibrium then it might be worth mentioning the initial condition and at what time t you are talking about. Otherwise, ##v_{1}+v_{2}+v_{3}>0##.
For example, let's say you have [A]=1 mol/l, and [B ]=[C]=0 initially. When you let the reaction start, and when t→∞, you are going to have an equilibrium. Or, if your initial condition is already the concentration at the equilibrium, then you already have ##v_{1}+v_{2}+v_{3}=0##.
It was late and I was in a hurry; in fact by my definition v1+v2+v3 ≠ 0 at equilibrium as all the reactions are going forward, though there is no net change in concentrations. I was thinking about the situation with a reversible reaction, if you consider the reaction rate the difference of the rates of forward and back reactions, but that isn't the situation here.
By the alternative definition, v1 = d[A]/dt etc., the relation you get is
v1/α + v2/β + v3/γ = 0
yes @mjc123, in fact I saw in some books that the velocity is defined with the ratio of the stoichiometric coefficient as ##v=\frac{1}{\alpha}\frac{d [A]}{dt}## instead to use only the derivative...
Thanks to all,
Ssnow
Things like that do get considered in theoretical chemistry.
For further discussion I would suggest you forget the complication for the moment of the α, β γ, just let us suppose they are all 1, which is complicated enough to be going on with.
The thing to realize is that your scheme cannot be the complete representation of anything chemical.
The scheme shows A transforming into B and then back into A going through C. But if that were all, in normal chemistry B can transform back directly into A.So a normal chemical scheme would include the reverse arrows at each step, one from B back to A and from A directly to C. etc. For a normal chemical reaction there would be a constraint on these rate constants
kabkbckca = kackcbkba
(obvious notation). This is called the "Principle of microscopic reversibility" - there are some quibbles about that and some prefer "principle of detailed balance".
The result of these principles is, you might say, boringness. Kinetics that could happen if it were not true do not happen normally.
So why think about it at all? As I said, it cannot be your schemes cannot be the complete representation of anything chemical. But it can represent something of which you have left out a part. for example , suppose one of the arrows represent a photochemical reaction (with constant illumination). Then the rate constants are not bound by the above equation. You have an input of energy which is not shown in the scheme. In a long time the system does not reach a true equilibrium, but a steady state.Unlike the approach to equilibrium, the approach to the steady state may not be monotonic. In many chemical mechanisms steady states are of interest and may be represented in figures looking like your scheme. Example, in enzyme kinetics you get schemes like illustrated below (sorry for quality). Here a substance, x, combines with enzyme E which exists in two interconvertible forms E and E', to form the interconvertible enzyme-substrate complexes EX, E'X which then convert into the reaction product P regenerating E and E'. Here E is produced from EX by two different processes – dissociation and catalytic breakdown. The effective rate constant for EX → E Is the sum of the two rate constants. We can observe reactions over a time where the total concentration of x is essentially constant, so we have a steady state. The microscopic reversibility relations hold for the disassociation rate constants only, not necessarily for the overall ones.
The equations for the resulting steady-state kinetics are complicated!
I can find some references for anyone interested. I would also be interested to hear from anyone else, firstly because I have the impression that this subject is dealt with within different specialities who do not know about each other, secondly because I would like to be brought up to date!
Likes Ssnow
Ok, thank you to all for the answer but there is another thing not clear. @mjc123 said that in the equilibrium case all velocities are zero, why ? I think the sum will be zero but the concentrations are free to change in different ways in the direct or inverse direction, or it is wrong? Ssnow
The definition of equilibrium is when all competing processes are fully balanced and there is no net changes in the concentration of any of the species. It does not mean that the reaction is not occurring but since there is no net change, so the net reaction velocities are zero.
As I said in post #9, I made that statement hurriedly and now think it is wrong.
I understand that there is no net change (globally) and that the reactions take place, but for me it is not clear why locally we cannot consider a velocity different from zero (probably very small), the equilibrium ##\alpha A \Leftrightarrow \beta B \Leftrightarrow \gamma C\Leftrightarrow \alpha A## says that:
##v_{1d}=v_{1i} \wedge v_{2d}=v_{2i} \wedge v_{3d}=v_{3i}##
where ##v_{id}## is the direct velocity of the ##i##-reaction and ##v_{ii}## is the inverse velocity of the ##i##-reaction ... not that all are zeros...
Ssnow
A few notes:
1. The cyclic reaction will not cycle as written (else it would be a perpetual motion machine). Consider the free energy of each of the states. Say α molecules of A has a free energy G1, β molecules of B has a free energy of G2 and γ molecules of C has a free energy of G3. For αA --> βB to occur the free energy change associated with the reaction must be negative (ΔG ≤ 0 which would mean G2 ≤ G1). Applying this to the other reactions in the cycle, we get the following system of relations:
G2 ≤ G1
G3 ≤ G2
G1 ≤ G3
which has the solution G1 = G2 = G3. Thus ΔG = 0 for all three reaction, and they are all at equilibrium. As discussed in the thread above, under these conditions, the net reaction velocity for all three reactions under these conditions is zero.
2. It would be possible to create a cycling reaction by coupling the reactions to a thermodynamically favorable process, say the conversion of D to E. For example, one could have a cycling system such as
A+D --> B
B --> C + E
C --> A
These types of cycles are common in various biological processes (such as the GTPase cycles that drive nucleocytoplasmic transport in cells)
3. There are many cases where there is a net creation and destruction of a molecule yet its concentration remains constant (e.g. we encounter these types of situations when studying metabolism) . While the concentration of a particular species may remain constant over time, this system is not in equilibrium because there is a net flux of molecules through the pathway. Instead, we refer to this situation as a steady state.
You can do that. But for ##v_{ii} = 0## (that was the original assumption) this implies ##v_{id} = 0##.
Ok if ##v_{ii}=0## for every ##i=1,2,3## sure all velocities (direct and inverse) are zero because nothing change in concentration (in the equilibrium case). I think this a trivial situation.
Ssnow
On a pedantic point, in English we talk about "forward" and "back" (or "reverse") reactions, not "direct" and "inverse". You may possibly cause confusion if you use these terms where the context is not clear (I encountered this recently in a post on chemicalforums).
FAQ: Relations on the Kinetic velocities in a cyclic reaction
1. What is a cyclic reaction?
A cyclic reaction is a chemical reaction that forms a closed loop, with the product of the reaction being the starting material for the next step. This process repeats itself in a continuous cycle.
2. What are kinetic velocities?
Kinetic velocities refer to the rate at which a chemical reaction takes place. It is a measure of how quickly the reactants are converted into products.
3. How are relations on the kinetic velocities determined in a cyclic reaction?
The relations on the kinetic velocities in a cyclic reaction are determined by measuring the rate of the reaction at different points in the cycle and analyzing the data to identify any patterns or trends.
4. What factors can affect the kinetic velocities in a cyclic reaction?
The kinetic velocities in a cyclic reaction can be affected by several factors, such as temperature, concentration of reactants, presence of catalysts, and the reaction mechanism.
5. Why is understanding the relations on the kinetic velocities important in cyclic reactions?
Understanding the relations on the kinetic velocities in cyclic reactions can provide valuable insights into the reaction mechanism and help predict the behavior of the reaction under different conditions. This information can be used to optimize the reaction and improve its efficiency.
